Results 1 to 15 of 27
Thread: Massive engine vibration after swap.
    Oct 2011
    109
    Well, I got the 95 engine swapped in just fine on my 92, but I have a problem. I am getting massive amounts of engine vibration from 1500RPM on. Enough to shake the entire car. Motor mounts are good, so I thought it was the harmonic balancer. Swapped the old 92 one on and it was still doing it. This isn't a misfire, it's a full blown, rattle the change in the ashtray vibration. Never felt anything like it before. I used the flywheel that came on the engine, but I am starting to wonder if it's shot.
    Weird thing is that if I hold my hand over the engine, I don't really feel much vibration, but I sure as hell feel it in the body.
    20,933
    Quote Originally Posted by DeanWinchester View Post
    Sounds like something in the flywheel, clutch or pressure plate area.
    Nov 2009
    Metropolis, IL
    884
    I thought the harmonic balancer was different between the 92 and 95.
    US Navy Veteran Retired Best Dyno 458HP 556TQ
    "I've done so much with so little for so long that now I can do anything with nothing."
    http://www.sccoa.com/forums/garage.p..._view&id=28414B
    Apr 2005
    Nor Cal
    2,976
    Balancers are different but they are both 0 balanced.
    The flywheels should both be 0 balanced also.
    I had repaired a 95 SC where another mechanic put an 89 counterweighted flywhel on and it had a nice vibration right around 1500 RPM's .. fixed that by 0 balancing the flywheel.
    Could also be driveline related .. was the driveshaft installed in the original position at the differential ?
    - Dan
    Oct 2011
    109
    Yeah, I thought the 95 balancer is different too, but it's identical to my old 92. So this "95 motor" might be an older short block with all of the new stuff on top. It definitely has 95 heads, intake, blower, blue top fuel injectors, and accessories.
    Not driveline related since it does it with the car sitting still. It has to be something wrong internally or the flywheel. I am done with the car, I am either going to part it out, or sell it dirt cheap. 3 engine pulls is my limit.
    Oct 2006
    48125,michigan
    4,137
    well then pull the tranny and changed the suggested fly wheel clutch and pressure plate
    Oct 2011
    109
    Quote Originally Posted by 92sclikenew View Post
    Nope. I am done. If I pull one more part off from this car, it's going to be for parting it out. 3 engine pulls is my limit for any car.
    Mar 2007
    Central Kentucky
    767
    There is an old saw about if you don't do it right you get to do it over, so don't blame the car......just saying
    I don't think I have ever owned a car that was finished---unless it was totaled.
    Feb 2004
    IA
    4,252
    Where are you located?
    Honor, Grace and Dignity......Remember these
    Jul 2003
    Eastern (nee Western) PA
    4,993
    It sounds like somebody probably installed the wrong flywheel. But I don't know where you got the 95 engine, so I don't know if that is even possible.
    I would suggest that you double-check the plug wire order at the coil pack, to rule out the really simple stuff.
    God bless!!!
    Former Birds:
    Apr 2005
    Nor Cal
    2,976
    Hmmm .. are you using the late model fuel injectors on a 1992 ??? Or did you put your original injectors on ?
    - Dan
    NYC
    17,430
    Your car wouldnt run wit the 95 balancer on it so whatever motor you have it was either in an earlier car in which stuff was swapped already or not a 95 engine. WhHat injectors are you using now?..Should be your 30lb red ones
    Oct 2011
    109
    Quote Originally Posted by old_coot View Post
    I am not a weekender mechanic, I did everything right on this car. First rebuild was done with a remanufactured crank, good rods, ARP hardware, and fel pro gaskets. All torque specs were followed, all clearances were fine. Second rebuild, I tore everything down, found nothing wrong, against my better judgement, I put in all new bearings and rebuilt it, only to have it start with a 2500RPM rod rattle. Then I went and heard the new engine run and it was in a 95 body car, I installed it and this BS happens. Tell me how I could have done anything differently.
    Quote Originally Posted by BirdofPrey97 View Post
    Kaufman, Tx.
    My guess as well, really the only thing that it can be. I have already double checked everything, just to be safe. I know the difference between an engine misfire and a vibration. Had a honda civic with a welded harmonic balancer and it acted just like this.
    Quote Originally Posted by Ddubb View Post
    - Dan
    They are the Dark Blue 36lbs injectors that came with the engine.
    Quote Originally Posted by XxSlowpokexX View Post
    I know. My working theory is that the owner of this 95 car had a bottom end failure and got an 89 short block that is supposed to have the weighted flywheel, but they reused their 95 flywheel.
    Injectors are the ones that came with the motor, dark blue 36lbs injectors.
    NYC
    17,430
    you need to put the 30lb red injectors back on. Car wont run right with 36's
    Apr 2010
    SLO County
    358
    There you have it.
    "I know. My working theory is that the owner of this 95 car had a bottom end failure and got an 89 short block that is supposed to have the weighted flywheel, but they reused their 95 flywheel. "
    Don't pull the motor. Pull the Tranny and try the flywheel. But first chech the sizing on the pilot bearing. It could either by the wrong one. I forget but I think I remember SC's have needle bearing type not a bushing. What if the needles are gone. Since you got a cobbled together motor it could be anything.
    Don't blame the car. JUST CAREFULLY RECHECK YOUR WORK, put on mechanics clothes, and take off that butcher apron you didn't know you got with that "95 motor". I always live by if I want something done right, I have to do it myself. Conversely if I did it and it's still need right, I just got a chance to learn something.
  1. 3.8L N/A, 3.8L SC, and 5.0L engines and engine swap kits
    By racecougar in forum Parts for Sale
    Last Post: 01-27-2011, 02:08 AM
  2. Engine Swap Questions
    By ThunderCoupe94 in forum Technical Forum
    Last Post: 10-15-2005, 05:42 PM
  3. Different Engine Year Swap??
    By Titanium Bird in forum Technical Forum
    Last Post: 08-07-2004, 01:09 AM
  4. HG's Fix original or swap engine?
    By Peterdroy66 in forum Super Coupe Club of Ontario
    Last Post: 03-07-2003, 06:59 PM
