Results 1 to 15 of 15
Thread: exhaust setup
    Sep 2011
    137
    exhaust setup
    I have a 91, is it worth 260 dollars (which it costs here in sweden for a 92 tank) to do the swap to the 92 tank? Will the sound change or the flow?
    What about mufflers and resonators? Resonator in the middle and mufflers in the back?
    Im running headers...
    Thank you
    Feb 2004
    IA
    4,252
    I never noticed any sound change. The drone came after removing the resonator, but that was solved by installing a magnaflo 2.5 dual in and 2.5 dual out.
    Honor, Grace and Dignity......Remember these
    20,902
    Quote Originally Posted by Tedor View Post
    Thank you
    No...I don't think it's worth much if anything in the power making department. You can make well over 400 rwhp using an early model fuel tank exhaust system.
    Mar 2006
    San Jose, Ca
    1,806
    I think late model tank is 1 gal less than early...so save little weight there...and it is easier to run dual piping through late model tank
    those are generally the benefits
    Sep 2011
    137
    Thanks for your input. One resonator and two mufflers at the end, is that the way to go for best performance and sound?
    NYC
    17,430
    the least drone seems to occur in the two in one out resonator then split back to two after the rear. You can fit a single 3.5" off the rsonator out to the back an dthen sp,it it off into two 2.5" pipes
    Basically (2) 2.5" into resonator (1) 3.5" out which will split into (2) 2.5" in the rear.
    Best for early model tank in my opinion. Stick to Borla mufflers for sound quality
    Home of the Whopper
    3,415
    I say yes to the newer tank because your exhaust will be a lot easier to route. The new one basically allows the exhaust straight through, the early one you have to do a 90 degree bend just to make it around.
    Home of the Whopper
    3,415
    Quote Originally Posted by XxSlowpokexX View Post
    I'm pretty sure you won't be able to route a 3.5 inch pipe around an early style tank. If you do, it will be so horribly disfigured that you will most likely end up with 2.75 inch choke points.
    20,902
    Quote Originally Posted by Micahdogg View Post
    I agree, that a 3.5" center pipe would be a very tight fit. Mine had a 3" mandrell bent center pipe with the early model tank. When switching to long tube headers and a much bigger exhaust I also switched to a late model tank...BTW it gained zero HP.
    Tedor,
    This thread has some pics of the old vs new exhaust that shows the center pipe routing differince.
    http://www.sccoa.com/forums/showthre...inless+exhaust
    NYC
    17,430
    I had a 3.5 inch in one of my older sc's. Mandrel bent. If you went with compression bends im sure it would be disfigured
    NYC
    17,430
    Tedor,
    I still find it strange that you got 0 benefit from the new exhaust as it really flows only as well as its 3" or less choke point.
    20,902
    Probably helping now that I've got a 4.2 motor, bigger cam and whipple supercharger. Just wasn't holding me back on the old 3.8 motor with 1.7 AR.
    Home of the Whopper
    3,415
    I just remember seeing someone mutilate a 3 inch pipe trying to get it around the old style tank. And knowing how tight this 3.5 inch pipe was on my new style tank, I wouldn't even attempt it on the old style.
    Sep 2011
    137
    Thanks for all the info!
    Can I have this magnaflow where the stock resonator would have been?
    http://www.magnaflow.com/02product/s...e=main&id=9983
    What magnaflow mufflers should I use in the rear?
    Thanks
    Mar 2006
    San Jose, Ca
    1,806
    if it is not directional then yes
  1. How Does the SCP Exhaust Setup Sound???
    By pablon2 in forum Non Technical Forum
    Last Post: 01-11-2005, 07:59 PM
  2. LONG Exhaust ? - I know they suck
    By ChaseTruck754 in forum Technical Forum
    Last Post: 12-23-2003, 02:35 PM
  3. Exhaust setup, PLEASE HELP???
    By studpike in forum Technical Forum
    Last Post: 05-12-2003, 02:15 AM
  4. Which exhaust setup to run?????
    By Tbirdsc Colonel in forum Technical Forum
    Last Post: 04-18-2003, 01:36 PM
  5. New Exhaust Setup to Debut at Carlisle
    By white91sc in forum Non Technical Forum
    Last Post: 05-09-2002, 04:51 PM
