Belisarius
This car has
I regret that I must sell my 1995 5 Speed SC. I've only owned the car for a few years, but my dad bought this car new. It was actually his last company car and he bought it from the company when he left. The car has never been in an accident. I got it from him, and I added some parts.
1995 5 Speed
Electric Red Clear coat
Opal Grey cloth/leather 6 way power seats
Miles: 104,292
Miles on new remanufactured motor: 22,032
NEW: Price: $4,000 or BEST OFFER. (price lowered again)
Southern California
San Pedro, CA
Modifications:
Vege ATK remanufactured SC engine (the manual transmission version) installed at 78,259 and properly broken in. Heads are stamped "SC".
SCP 3" Cold Air Intake
76mm MAF
75mm Throttle Body
MP Raised Top
3" Pulley Boys Compressor Pulley
SCP heavy duty SC belt tensioner springs
Double IC
SCP 2.5" down tubes + cats
Kooks Mid Length Headers
2.5" Custom True Dual Mandrel Bent Exhaust
Chuck W Type 8 Engine Mounts
Kene Wagner Double Intercooler
Raceware Alumnium Radiator
SCP Cross Tower Brace
New Tokico ARC shocks
Control Freak Diff Cover
Lincoln Mk VIII Pumpkin
Lincoln Mk VIII LCA
Lincoln Mk VIII 3.08 Ring and Pinion
DLF Delrin Bushings for LCA
DLF Delrin Spring Perches
DLF Running River Steering Link
Quarterhorse with sidesaddle
David Dalke Base Tune
Cobra 10th Anniversary Front Calipers
Cobra Rear Calipers
Cobra hubs
17x9 Bullit Style Wheels
Addco 1.125 Rear Sway bar
DLF Rear Sway Bar Bushings and Mount Kit
New battery
New starter
'95 SC Factory Manual
Ford Specifications Manual
New: I forgot to mention the new and unused 17" spare wheel and tire.
The only things wrong with the car:
Needs to be painted.
Odometer went out at 92,927 Odometer repaired and working. It reads 104,000.
It hasn't been lowered.
Airbag light is flashing Code 51 [Code 51 is an intermittent short to ground. The shop is tracking it down and an oem airbag computer is $30 on eBay.[/b]
Once in a Blue Moon the QH will loose its program. I re-flash and everything works. The QH can be disconnected. The Quarterhorse has been removed. It appeared that, either in vibration or installation, that the chip had partially pulled away from the PCM diagnostic port. There was a bracket but nothing actually holding the chip on other than contact friction. To re-install the chip would not be a problem but it appears that it needs to be secured with something in addition to contact friction.
I'm currently driving this car once a week or so; everything is working smoothly except as noted above.
PM me with any questions. This car is fun, fast and awesome. I love it, but I need to cut back on expenses.
Sold!
1995 5 Speed
Miles: 104,292
Southern California
San Pedro, CA
Modifications:
76mm MAF
75mm Throttle Body
MP Raised Top
Double IC
Lincoln Mk VIII LCA
Cobra Rear Calipers
Cobra hubs
New battery
New starter
