Page 14 of 14 FirstFirst ... 41011121314
Results 196 to 199 of 199
Thread: 92 SC timeline
  1. #196
    Sep 2011
    Mcallen TX
    774
    Well after quite a few hrs I managed to get really close to finishimg the plenum to.match the mammoth size 95mm throttle body
  2. #197
    Sep 2011
    Mcallen TX
    774
    I started more work I swapped out one side of springs well almost I have some issues with a rounded bolt ,
    I also started on my 145 speedo
    And a few things that got here for install
    So much to do I wish it was already all done so I could drige it
  3. #198
    Sep 2011
    Mcallen TX
    774
    Here are some more pics adding more bling as well
  4. #199
    Sep 2011
    Mcallen TX
    774
    I have not done much work and I cant keep up with the all the modifications waiting to be done but here is the most recemt updated list of stuff that I have but need time to install
    Interior
    145 speedo
    Custom white faces and led lightning
    Weight reduction where possible
    Alum instrument cluster bezel
    Rear end
    New ford racing 3.73s and FRPP install
    S spring off cobra
    rebuild the trac lok with 8 clutch set up
    solid pinion spacer kit to replace crush sleeve
    lpw ultra irs cover
    Solid irs mounts
    Pair of fat halfshafts
    Engine
    93 steel covers
    Sfi bhj balancer
    ★☆ported big valve heads
    1.94Intake 1.70 exhaust valves yella terra 1.73 rockers
    ☆Match ported and modified lower intake
    *Cam
    ---HV oil pump
    --New water pump
    Front cover gaskets etc
    -Turbo chuck poly motor mounts
    Bolt ons
    95mm TB
    10mm livewires
    Light weight anodized alum PS pulley
    76mm Billet alum idler pulleys
    Wiring intercooler fans
    Kooks mid lenght headers
    MP abradive rotors
    15% 10 rib pulley kit
    Tires
    315 35 17 nitto nt555r drag radials on my cobra Rs 245/45 on fronts
    Trans
    Tru cool plate trans cooler
    10" fan for cooler
    Dirtydog deep alum trans pan +2.5qts
    Automether phantom 2 trans temp gauge
    Lentech valve body street terminator 2
    Suspension/driveshaft
    Finally going to drop my rear with the 1.6" vogtlands and tokico illumina 2s
    Got an air lift kit to add to the rear
    -dynotech 3.5" alum driveshaft
    -NHRA approved driveshaft loop
    -raybestos Pro front suspension:
    Inner tie rod ends
    Outer tie rod ends
    Lower control arms
    Upper control arms
    -rear derlin bushings
    -late model front spindles
    Mark 8 alum rear LCAs
    DLF perches
    Brakes
    -Stainless steel brake lines all 4 corners
    -cobra calipers
    -13" drilled slotted rotors
    -rear drilled slotted rotors
    -ceramic pads front and rear
    Fuel
    Racetronix fuel pump wire upgrade for the 340lph
    95lb injectors
    Other stuff
    75-125hp zex wet kit
    Zex red Led purge kit
    Zex Bottle warmer
    Nx Remote opener
    Zex Bottle blanket
    Nos gauge
    -stage 2 snow dual nozzle methanol injection kit
    Body
    -race weight 3" cowl hood with heat extractor
    -front bumper lip
    Tuning
    -binary editor (tuning)
    Moates quarter horse
  1. For that person that ask can a sc beat this car.
    By catwithboost in forum Non Technical Forum
    Last Post: 10-09-2013, 06:06 PM
  2. Needing Tranny Rebuild help
    By thundrburd in forum Technical Forum
    Last Post: 05-15-2011, 08:18 PM
  3. 1992 SC 5-speed Manual NEED TO SELL ASAP.
    By pepito6SC in forum Cars for Sale
    Last Post: 05-24-2005, 01:37 AM
  4. 8.8 Differential Rebuild Kits:
    By Rich Thomson in forum Technical Forum
    Last Post: 06-22-2004, 07:46 AM
  5. AOD Tranny rebuild kits...
    By tbirdman in forum Technical Forum
    Last Post: 05-15-2004, 12:33 AM
