Results 1 to 2 of 2
Thread: What does this code mean?
    Jan 2012
    Dunnellon,Fl
    10
    P1443 Secondary emission system. Wreaking havok with my car.
    Apr 2005
    Nor Cal
    2,976
    Code is for the EVAP Purge control solenoid, check your vac lines and PCM signal to the purge solenoid there is also a flow monitor on the 96/97 OBD2 TBirds.
    Shouldnt affect driveability much, its not used all the time - unless you have a hose causing a vacuum leak on the engine side.
    - Dan
  1. '94 EGR Code Trouble
    By Burn_out_Bob in forum Technical Forum
    Last Post: 01-08-2010, 11:36 PM
  2. code problems
    By metanoiadude in forum Technical Forum
    Last Post: 05-06-2007, 03:17 PM
  3. Rock Auto Discount Code
    By rickbtbird in forum Non Technical Forum
    Last Post: 08-11-2005, 06:47 AM
  4. Looking for proper way to do KOER test
    Last Post: 04-22-2005, 11:58 PM
