Code is for the EVAP Purge control solenoid, check your vac lines and PCM signal to the purge solenoid there is also a flow monitor on the 96/97 OBD2 TBirds.
Shouldnt affect driveability much, its not used all the time - unless you have a hose causing a vacuum leak on the engine side.
- Dan
