Page 1 of 4 1234 LastLast
Results 1 to 15 of 48
Thread: My first car.
    Jan 2012
    Madison, OH
    82
    My first car.
    Hi everybody. For those of you who don't know me already, my name is Phillip Dalke and I am the son of the famous David Dalke. I am 17 years old and a junior in high school.
    My dad and I purchased Mark Kovalcik's cougar back in the summer of 2009 (I had just turned 15) with no powertrain. After that I got to watch it sit in the driveway. It sat there (about a year) till there was sufficient space in the shop and I got the motivation to start this long project. Well, it wasn't originally planned as a long project, but that's just how sc's seem to turn out.
    Once it was in the shop, one of the first things I did was rebuild a 5-speed transmission for the car so I could swap the auto for a manual. After that we got to work on a motor for the car. We ended up getting a stock motor from Corey Binks that supposedly only needed headgaskets. Back at the shop I tore the motor down and found some not-so-nice wear on the cylinder walls. Dad decided that wasn't acceptable and decided the motor would have to be rebuilt. In the end it was rebuilt with good used parts that were found in SCU inventory, including pistons (mix-matched set), forged connecting rods (four were bent and had to be straightened, one on which may still have an S-curve in it, as it's shorter that the rest), a cam with .600 lift (originally it had been damaged, but Dave worked his magic and polished it to be acceptable), heads that are not ported, but do have a nice, 5-angle valve grind and big valves (originally one of the valves did not seat properly, so we just ran it hoping it would work itself out), and 1.73 rocker arms (more than half had flat spots on the rollers, which had to be replaced). The motor is topped off with a ported early model blower with coated rotors, a raised top, and a 5% pulley. It runs really strong for a pile of leftover parts.
    Back to the car itself. While we had the motor out, we noticed it had several cracks in the firewall, testament to the many aggressive launches the car had experienced. We decided it was best to fix them now while the motor was out so I got to work taking the dash out so they could be welded. Once the dash was out and the carpet/underlay was peeled back we could get to the bare metal. However, that turned out to be more of a curse than anything else.. Under the carpet we found rust...lots of it! There was no way we could put the carpet back down over top of it, so began the tedious job of rust repair. Out came the seats, front and back, the carpet, and wiring. There holes under both the driver and passenger's feet, as well as the floor right in front of the back seat on the driver side. Eventually all of the cancer was cut out and the unibody repaired. It was also at this time the firewall was repaired, the pedals swapped, and the wires for the trunk-mounted battery rerouted. That took the longest of any work we did to the car. Dad says I'm lucky I'm his son because he won't do rust repair every again for anyone. Thanks Dad!
    Fast forward and the motor is in the car, along with the trans, driveshaft and 2:73 gears. We also swapped the mustang hubs for Supercoupe ones because the wheels I decided I wanted on the car were Supercoupe bolt pattern. The car also has the 13" brake upgrade, along with blue tokico shocks and chassis bracing.
    Finally the car fired up for the first time in many years late January, but car was far from drivable. First on the list of problems turned out to be the clutch switch. The car would want to die when you put it in gear. Eventually we found our wiring error and solved that problem. When we finally tried to drive the car, it would lurch after shifting. The computer told us that the TPS, ACT, and ECT sensors were not working, specifically when the car was acting up. After some diagnostics and tracing the wiring diagrams, we solved the problem by adding an extra ground to that circuit. Then, Dad drove it for a couple of days before the ABS kicked out. Dad said my problem was either a bad pressure switch or bad pump. I really didn't want to have to change either so I got kinda mad and depressed with the car because I had worked so hard and so long on the car and it still wasn't drivable. I took a break for a while and today I decided I would tackle the problem. First, I tested for power at the pump, and low-and-behold, after wiggling the connectors the pump worked! Yeah! So I cleaned all the connections and added some grease and hopefully that solves the problem. Now hopefully, after a year and half, my car can be done.
    Recently we got the car on the dyno and it put down some pretty impressive numbers for having an early blower and stock intercooler IMO. It is officially faster than my fatherís car. See dyno sheets below.
    First on the list of upgrades include a FMIC, some gauges (probably oil pressure and AFR), and a stereo system.
    Wow...that was rather long winded. Thanks to anyone who took the time to read my story. I look forward to sharing information and experiences, as well as general bs-ing with everyone.
    Thanks again,
    Phillip
    Will work for performance parts.
    Dec 2002
    Wintersville, OH
    4,089
    So are you daily driving the car now?
    Making woosh sounds since 2010!
    Jan 2003
    Woodbridge, VA
    5,145
    Better get to sleep its a school night.
    I think Dad should be the Infamous David Dalke.
    Dang the kid can put some sentences and paragraphs together. Must not be a texter.
    Anyway welcome, youngin.
    ~Chris
    SCCoA Member #1826
    Bettie Riding jack stands
    SCARlit on drag duty now
    Nov 2003
    Madison, Ohio
    208
    Be safe, my child.
    Sep 2004
    Indy
    5,623
    I'm glad that you do as well with cars as you do in English class, bro. Did you accidentally call your dad "Dave" or is there another one at the shop?
    Have fun with the car and be safe. No turbos for you until you get comfortable with driving an SC! Most people on here are still at that stage, so no worries.
    1994 SC
    4.5L Twin Turbo SVO
    Project GTFD
    20,948
    Welcome Phillip. Really glad to hear you've got the car running. That car has always been one of my favorites in the club. Congrats on making some very impressive power for the mods you have.
    PS: Hope to see you on the Power Tour next month.
    Greenville, IN
    4,329
    I was wondering when you'd finally sign up Philip. Congratulations on getting the car driveable! It does get very frustrating at times...especially when it seems like everything is falling apart on the car. Sometimes taking a break from the work for a little while helps.
    Also congrats on the dyno numbers! Looks pretty dang good to me!
    Matt Haub
    Black '89 5spd - 281K miles, MPx, E85, Alky-Inj ¶ RWHP: ? RWTQ: ? ¶ Best 1/4mi:12.521, MPH:107.23mph
    St. Louis, MO
    6,427
    Good to see you here Phillip. Now that you've made it past all of the early pains with your car, you should be good for a while.
    Kurt K (e-mail)
    SCCoA Member #: 443
    Clear Lake, Houston
    1,196
    I am impressed with the story. If all the youngun's were so proper.
    And welcome. And good luck.
    95 SC Auto
    95 SC 5-speed Toy
    Rodney
    Best time 95 5spd 14.58 @ 93.50 totally stock and tired.
    May 2007
    Wilmington MA
    1,091
    Yay, another guy on the forum that's not an old fart
    Welcome
    May 2003
    Omaha, Nebraska
    6,207
    Looking forward to watching the progress on your car and swapping stories
    Ken
    93 SC Whipple powered 11.648 @ 119.6
    Twin Turbo, air intercooled..yet to see
    Madison, Ohio
    17,574
    Thanks for all the replies guys.
    It was too late last night for me to resize a bunch of pictures, but here they are.
    I do plan on driving the car daily, but I don't have insurance, so that hasn't happened yet. Hopefully that issue will be resolved within a week so I can drive my car on the road for the first time.
    Email me here.
    Jan 2012
    Madison, OH
    82
    Sorry, forgot to switch log-ins....
    I'm going to have to make double sure of that next time.. I'm still new to this..
    Anyway, more pictures.
    May 2004
    Va. Beach,Va.
    7,002
    Welcome aboard Phillip, I'm sure that in a couple of years I'll be trying to catch you instead of you trying to catch me. Listen to your dad because he's "been there/done that" plus he can save you a ton of money.....
    SCCOA Member #2406
    '94 SC AUTO - 2.3 Whipple
    '90 SC AUTO - Bone Stock
    Dec 2002
    Wintersville, OH
    4,089
    Doin work with that wrinkle finish!
