cruise control mystery
foxback
does anybody know where the cruise module is located on the early SC s ? The later cars had it on the brake pedal bracketry and is easy to find!
it dont work at all and have swaped everything but the control module and thats because i cant find it!
Before you replace anything, make sure the vacuum dump switch on the brake pedal is adjusted correctly!
That being said ... The solenoid is in the driver's fender, behind the splash guard.
yup did all that still cant find the module ta swap it!
I don't know what you mean ... what module are you looking for? The mechanical actuator is in the fender. The control is (I believe) handled through the EEC. You want to swap the entire engine computer?
