Page 1 of 2 12 LastLast
Results 1 to 15 of 24
Thread: MPX case pictures can it be fixed?
    Sep 2004
    Herrin Illinois
    3,402
    Here is a before and after pic of the MPX I am attempting to fix let me know what you think btw .005 was removed
    member #2488
    NYC
    17,430
    Why dont you try getting a teflon coating or something in there..I know thats been done before
    Sep 2004
    Herrin Illinois
    3,402
    I intend to send it to wade at high speed labs in stl. I have purchase a gen 5 m90 off of a low mile grand prix (which is much more efficiant than the early model) and have him put the newer rotors on a 95 m90 bearing plate. He will coat the case add new bearings and seals to the front plate mount the new coated rotors on the sc shafts re time them and check it for clearance. I plan on putting my stock pulley back on and adding a snake bite internal 30% overdrive to the snout as well. I just want to get opinions on it before I kill my wallet lol
    member #2488
    Sep 2004
    Herrin Illinois
    3,402
    well I put some bearings in it and a decent 95 rotor pack and ut sounds good and pushes good air. I didnt have a feeler gauge to check the tolerence but hopefully I can tomorrow but everything looks pretty good so far .
    member #2488
    NYC
    17,430
    All you need to do to use the GTP rotor case bearing plate and all is move a dowel. I had done it back in the day
    Sep 2004
    Herrin Illinois
    3,402
    Quote Originally Posted by XxSlowpokexX View Post
    Not on a gen 5 the shafts are longer and the bearing plat is different, they will have to be removed anyway because I am having the front bearings replaced with larger more durable front bearings. I have been through more rotor packs in the cars I've owned than I care to count, no more rotor jingle at idle for me I'm going to do this one right!
    member #2488
    20,933
    Dave,
    I'm sure Wade can fix that case. I had one of his ported early model superchargers that had the case over bored then filled with some type of plastic coating and re-machined for a tighter tolerance than the original bore. I think it was one of his better ideas.
    PS: I'm golfing tomorrow, so I won't be able to meet up with you and Kurt for lunch.
    Sep 2004
    Herrin Illinois
    3,402
    I am going to have him coat it and do a complete rotor rebuild on the entire mpx with 07 gtp rotors that are supposed to be quite a bit more efficiant, that coupled with the overdrive in the snout should make some pretty nice numbers I hope. I was just lucky to have a pretty good machinast remove most of the buildup from when this came apart so this can be done. Well thats too bad about lunch I am going to take my car up tomorrow but there will be other times im sure. Got to work on my game a little but would be cool to get together sometime and play I sent you a cpl text messages one about a scotty cameron putter ive got for sale thanks David for all your guidance talk to you soon!
    member #2488
    Nov 2005
    Fort Wayne, Indiana
    2,985
    Are 07 gtp rotors different than the series II 3800 engine supercharger rotors??
    chris
    Me-89 SC 5-speed 1.7 Autorotor twin screw over 443rwhp 20psi
    Her-95 SC auto 1.7 KB 400rwhp 17psi
    my email
    Sep 2004
    Herrin Illinois
    3,402
    Quote Originally Posted by mywhite89 View Post
    chris
    yes they are completely different even though they are a 3 blade design th cool down the air compared to the earlier rotors and also have a different profile so they produce more boost.
    http://www.eaton.com/Eaton/ProductsS...ers/PCT_223744
    member #2488
    NYC
    17,430
    Quote Originally Posted by davec73 View Post
    I would think if they have a different profile youll need to use the timing that the current rotors use no?
    Sep 2004
    Herrin Illinois
    3,402
    Eh I dont know much about timing the rotor packs or I would rebuild the four I have now but I believe the timing has less tolerence than the early modle and the meshing of the rodors makes it up to 30% more efficiant. I had a fully ported gen3 sc on my grand prix inlet outlet you name it. I upgraded to a gen 5 and it pushed 2 to three psi more boost and lowered the amount of KR I had or knock which kills these engines. So with these rotors I am hoping to cool down intake air temp and produce more boost with less overdrive
    member #2488
    20,933
    Damon,
    I got this from the link Dave posted.
    It features two three-lobe rotors, twisted 60 degrees
    Sounds like rotor timing and outlet design will be like every other M90.
    Oct 2007
    US, Mi, Detroit Metro
    125
    Wow this sounds like something I may want to do myself.
    Where you get all the parts you mentioned and whats the price of this service in STL?
    Sep 2004
    Herrin Illinois
    3,402
    Quote Originally Posted by samishii View Post
    600 is the price for setting up and re coating the rotors. I spoke with him today and he said they will work on our shafts. I paid 340 or so for my grand prix gen v blower. I knew I would be spending some money when I started this venture
    member #2488
  1. Want an MPx CASE, will trade or buy
    By supercharged3.0 in forum Trades
    Last Post: 03-14-2010, 03:25 AM
  2. Porting an MPX.
    By ricardoa1 in forum Technical Forum
    Last Post: 01-20-2010, 09:03 AM
  3. S port pictures
    By kenewagner in forum Non Technical Forum
    Last Post: 12-25-2009, 02:15 PM
  4. I FIXED it I FIXED it I FIXED it ya
    By PETEp in forum Technical Forum
    Last Post: 08-08-2006, 10:35 PM
  5. fixed, fixed, fixed!!!!!
    By 94scnflt in forum Super Coupe Club of Southern California
    Last Post: 02-19-2003, 03:41 AM
