Mike Brendzel
Looking for
ABS Brake Master Cylinder Assembly - Teves Mark II - (1989 - 1992)
I have a few problems with mine but I have been able to get it fixed so any help I can offer I will
If you have no dash warning lights then the issues is not the ABS system. If the ABS system fails, the lights will come on.
I'm with Dave on the ignition switch.....
But you really need to find out where the brake fluid id coming from.....
Most likely the front seal of the pump motor or the rubber supply line from the reservoir to the pump....
Sounds like a pressure switch problem.....
When there is no brake fluid pressure to the switch, the pump will run.....
Once the proper pressure is achieved, the pressure switch breaks ground to the pump motor.....
Now you have to find the leak....
If the soft hose leaks, you can get a replacement from Contitech. It is the same type of hose used on 84-91 BMW 3-series cars. I mention this because you may find that easiest to get in Europe.
