Results 1 to 12 of 12
Thread: Speedo mileage/trip odo
    Jan 2012
    Dunnellon,Fl
    10
    Hello,
    I have a '96 Bird. My odo & trip odo stopped working
    I swapped it out with another from a '94.Still not working
    What am I missing? Speedo itself works fine
    thanks for the help.
    Greenville, IN
    4,329
    There are two plastic gears that go bad in nearly every assembly over time. If the speedo is working, that is your problem. It's not easy finding a good used one!
    Search: "odometer gear replacement" for places to buy, and there should be a how-to somewhere around too.
    Matt Haub
    Oct 2004
    Charlotte, NC
    8,159
    If you look around the yards, find one that doesn't have 000.0 on the trip odometer and you are good to go.....
    May 2004
    Bmore
    3,228
    any update on this. I have the same issues, OD gears replaced and the OD still doesnt work. Speedo is working fine. I took another gauge popped it in and still no OD.
    Jan 2010
    Bossier City, LA
    2,222
    Double check the wiring to the motor that drives the odometer.
    Check the assembly.
    Past that, there's not much else.
    RwP
    Greenville, IN
    4,329
    Quote Originally Posted by Dahoopd View Post
    There are only three electrical connections to the speedo/odo assembly, and both the speedo and odo are driven off the same signal from the VSS, so there's something wrong with the extra gauge too. Probably the gears are disintegrated. About 4 of 5 gauges are bad by now!
    Did you make sure all the little pieces of old gear were cleaned out of the assembly?
    Matt Haub
    May 2004
    Bmore
    3,228
    I took the dpeedo apart that had the gears replaced and found the gears were once again broken. I went to SCP to order them and found that they aren't $40 any more when I bought them but now $80. Thats just pure rape.
    May 2004
    Bmore
    3,228
    and for anyone looking, this site has them for $39 for both gears NOT $80.
    http://www.transmissioncenter.org/Odometer_Gears.htm
    Jan 2010
    Bossier City, LA
    2,222
    $42 for those after 1989.
    But *blink* I drive BY there every day almost!
    I may stick my head in and see what they sell over the counter for ...
    RwP
    Sep 2004
    Herrin Illinois
    3,402
    I posted a link to the vendor out of la that has them, they told me ford put a lubricant on the gears that makes them brake. You can buy the small gear or both of them from this vendor i think its in the rrstoration section
    member #2488
    Jan 2010
    Bossier City, LA
    2,222
    Quote Originally Posted by davec73 View Post
    That's what I mean - their office is about *does a quick Google Maps* less than 4 miles from my house.
    Never THOUGHT about checking there.
    *almost slaps head, puts fork and knife down first, THEN slaps head*
    RwP
    Apr 2008
    Vancouver, Washington
    389
    This thread is awesome because my car has had 173,*** miles on it for the past 5000 miles probably! lol
  1. need a speedo that counts miles prefer 145 over 120
    By whitebird94 in forum Want to Buy
    Last Post: 05-24-2010, 05:06 PM
  2. Replies: 3
    Last Post: 07-29-2008, 04:44 PM
  3. Speedo OK.......Odometer Broke. Any Ideas?
    By edspringer in forum Technical Forum
    Last Post: 02-27-2008, 10:11 PM
  4. Speedo works but Odo doesn't turn
    By sledgehammer in forum Technical Forum
    Last Post: 05-15-2007, 08:46 AM
  5. speedo and rearend gear question
    By x182dan in forum Technical Forum
    Last Post: 02-19-2005, 04:17 PM
