Results 1 to 11 of 11
Thread: school me on roller rockers
    Mar 2009
    Northford, CT
    252
    looking into getting a set of these:
    http://www.harlandsharp.com/ford_v6_v8.htm
    im looking for the easiest path for install ill assume going with the 1.73 ratio will require the least amount of adjustment. im looking for direct bolt on appliance, im not interested in taking any of the engine apart which is why im not jumping into getting a new cam just yet. anyone install these before? perhaps a writeup you can throw me a link for? thanks guys
    21,122
    Save your money for something that's actually going to add power.
    Sep 2004
    Herrin Illinois
    3,440
    I have these in a 1.8 non adjustable but I think the 1.73 is the stock ratio so? not going to really make alot of difference in performance for quite a bit of work? I think you would need to run 1.8s on a stock setup to see any diffrence.
    member #2488
    Mar 2009
    Northford, CT
    252
    roger that, thats the kind of truthful opinion i was looking for, haha. so maybe the 1.8s would be a good addition when i do open up the engine for some internal modification as a means of valvetrain durability, yes? but nothing for a quick bolt on deal
    NYC
    17,432
    1.8's would give you some more lift. But quite honestly with a car revving under 6,000 rpms I dont see a need for roller rockers at all. Just one more thing to go wrong. Even with a cam. On an SC I have used the stock rockers shimmed with aftermarket or reground cams with great success. And with a cam you dont really need those 1.8's
    Mar 2009
    Northford, CT
    252
    noted, id be looking at roller lifters and some high rate springs too but if youre thinkin i dont need them then im good with the advice
    Nov 2009
    Metropolis, IL
    884
    Quote from an engine builder:
    Lower friction/heat the oil less, can handle higher spring loads, may provide more consistent ratios, may or may not be higher ratio than stock, weigh more, don't necessarily add ANY power to the engine, require much less oil and therefore oil supply to the upper valvetrain can be greatly reduced and thus oil control can be improved.
    US Navy Veteran Retired Best Dyno 458HP 556TQ
    "I've done so much with so little for so long that now I can do anything with nothing."
    http://www.sccoa.com/forums/garage.p..._view&id=28414B
    Manchester, NH
    2,064
    Quote Originally Posted by nmcbchief View Post
    you got that right about reducing the amount of oil needed for the valve train. We used to cut the oil to head completely for our pure drag race applictions. Each rocker arm had a grease fitting installed and prior to each run we would shoot a shot of grease into each rocker. Of course this wouldn't work at all for a street application but it did help for short quick runs. :-)
    21,122
    Quote Originally Posted by Lycaon1349 View Post
    No..you would be better off installing a mild cam that will work with your stock valves, springs and rockers.
    There are three main things that are going to make more power on an SC motor: Better flowing heads, more agressive cam and an upgraded supercharger. Nearly everything else is just done to support those mods.
    If you are looking for easy bolt on mods that you can feel by seat of the pants: Install a 5% OD jackshaft pulley, a set of Underdrive pulleys and a less restrictive resonator. If you still have some money left over, some gears would be my next suggestion. Switching to a set of 3.73 gears in an automatic equipped SC will make the car feel about 500 lbs lighter.
    Jul 2003
    Eastern (nee Western) PA
    4,993
    You already have roller lifters. Improving the springs might give you something ... but I wouldn't mess with them until you have a better cam.
    God bless!!!
    Former Birds:
    Mar 2009
    Northford, CT
    252
    mines a 5 spd and i actually just switched to a 3.27 carrier, i love it, so much better than the stock 2.73s
    ooo did not know that, im still relatively new to these cars as far as the internals go, did a headgasket on my first SC but that was as far as i got into it. so this is my learning car, haha
  1. 1.95 ratio roller rockers
    By 92bird in forum Technical Forum
    Last Post: 02-27-2012, 11:24 PM
  2. Group-buy scorpion 1.73 roller rockers!
    By victor malvar in forum Group Purchases / Specials
    Last Post: 05-23-2011, 01:29 PM
  3. cam, roller rockers, pushrods, intake
    By Kevin Leitem in forum Parts for Sale
    Last Post: 01-22-2008, 05:54 PM
  4. 1.72 roller rockers
    By cachethunder in forum Technical Forum
    Last Post: 08-14-2007, 11:02 AM
  5. roller rockers
    By ZOOMBUGGY3 in forum Technical Forum
    Last Post: 10-21-2003, 01:03 AM
