Results 1 to 15 of 20
Thread: Big brakes and other performance parts.
    Nov 2002
    Columbus, Ohio
    6,924
    Guys since I've had little interest in my car I'm looking at parting it out. I have tons of good very low usage parts available.
    Big brake setup front and rear -Front brakes are 4 piston Brembo calipers with 13" cobra rotors, good pads, steel braided brake hose, 92 spindles with mustang bolt pattern. Rear brakes are stock sc calipers with FastEd relocation brackets and cobra rear rotors, rear spindles are modified to accept the relocation brackets and steel braided brake hose.
    Make offer on the brakes.
    -350HP 5.0L 306ci. -$2500 obo
    -Flaming River quick ratio manual steering rack with inner and outer tie rod ends to work on our cars and Flaming River billet u joint welded to the steering shaft to go with it. This setup was used once at Putnum park in May. Turns the big 275 front tires awesome even sitting still it took little effort. Make offer.
    Addco front 1 3/8 sway bar and 1 1/4 rear sway bar- make offer.
    Mark8 aluminum rear lower controlling arms- make offer
    Mark8 '93 one piece aluminum driveshaft cut to fit a 5spd sc. Make offer
    Mark8 aluminum pumpkin with good trac lock and 373 gears- make offer
    Two M5R2. One is a good 94/95, other is a 92 that's starting to grind a little going into 2nd and 3rd. Make offer
    Center force dual friction clutch and 5spd swap parts. Make offer
    After all is said and done I'll probaly let the body go that has a full cage and everything left inside it for 1500 obo
    PM, call or text 614-668-5507
    Shane
    Mar 2003
    Edmonton, Alberta Canada
    3,004
    Ballpark the pricing man. Possibly interested in brakes and swat bars depending on price.
    Jan 2003
    Woodbridge, VA
    5,129
    Interested in the rack, got a ballpark?
    ~Chris
    SCCoA Member #1826
    Bettie Riding jack stands
    SCARlit on drag duty now
    Aug 2011
    Kansas City, KS
    1,141
    I'm interested in the Mark 8 drive shaft for a 5 speed. I just don't know what to offer. How about 100 bucks shipped?
    Nov 2002
    Columbus, Ohio
    6,924
    PM's sent to everyone that sent me one and posted here.
    Shane
    ny\long island
    2,662
    sc parts
    selling any struts or shocks, any motor parts? underdrive pullies ..etc?
    Nov 2002
    Columbus, Ohio
    6,924
    Quote Originally Posted by pock1 View Post
    I do have a set of Konis to sell off this car. Engine was a 5.0L so I don't have any performance 3.8L SC stuff. Let me know if you are interested in the Koni's.
    Shane
    St. Louis, MO
    6,406
    message sent.
    Kurt K (e-mail)
    SCCoA Member #: 443
    20,928
    Quote Originally Posted by quick35th View Post
    Shane
    Shane,
    I'm interested in the Konis...please PM me a price.
    St. Louis, MO
    6,406
    Shane,
    hey stand back
    Kurt K (e-mail)
    SCCoA Member #: 443
    20,928
    Quote Originally Posted by Kurt K View Post
    hey stand back
    Yeah I figured that's what you sent the PM about..
    Jun 2003
    Lexington Kentucky
    1,520
    I tried to PM you back but it says your box if full. Just PM me your Email and I will get back at ya.
    Anthony Arnold
    Home of "No Cash Racing!"
    Silver 90 AOD 12.03 @ Shootout 2010
    White 94 Auto ??????
    Black 95 5-speed ????
    Jun 2007
    Whitby On. Canada
    966
    Hi Shane,
    PM is full, can you please send me some more info on your 306?
    Thank you
    Drew
    Nov 2002
    Columbus, Ohio
    6,924
    PM box is cleared up. Anthony try sending your PM again.
    Shane
    Nov 2002
    Columbus, Ohio
    6,924
    Quote Originally Posted by 91bird View Post
    Hi Shane,
    Thank you
    Drew
    Drew,
    Ford 5.0 stroked to 306ci originally out of a '92 mustang GT. Low mileage since rebuild. This engine produces 350HP at the crank, about 315-330 at the wheels on past dynos. Heads are Trick Flow Twisted Wedge heads, ford x303 cam, Trick Flow 1.6 roller rockers, comp cams promagnum push rods, crane double roller timing chain, MSD distributor, ford racing plug wires, ford racing valve covers, stock crank and rods balanced and blue printed, speed pro .30 over hyper pistons at stock compression ratio, edelbrock performer rpm intake manifold, mighty demon 650cfm carb and one inch carb spacer, 7 quart drag oil pan. Engine will be sold complete turn key from carb to oil pan. Headers do not go with it. The engine is still in the car, you can come hear it run before purchase. It does not smoke or rattle. Runs strong.
    Shane
