Page 1 of 9 12345 ... LastLast
Results 1 to 15 of 124
Thread: Operation 10.0
    Jan 2003
    Woodbridge, VA
    5,283
    Operation 10.0
    Its started! That's all for now.
    ~Chris
    SCCoA Member #1826
    Bettie Riding jack stands
    SCARlit on drag duty now
    NYC
    17,432
    tease
    Jan 2003
    Woodbridge, VA
    5,283
    Quote Originally Posted by XxSlowpokexX View Post
    tease
    I know. I hate build threads too. Usually takes too long for updates.
    ~Chris
    SCCoA Member #1826
    NYC
    17,432
    Tell me about it!
    Sep 2004
    Indy
    5,623
    I never did build threads until now. It does blow.
    Fuel cell time! Gotta put that turd on a diet, too.
    1994 SC
    4.5L Twin Turbo SVO
    Project GTFD
    Oct 2012
    columbus ohio
    113
    well conqrats and cant wait to see when you get it done man. i am getting my winter build parts a little at a time.
    Jan 2003
    Woodbridge, VA
    5,283
    So I was looking under the car last night and got to thinking. What are your thoughts on making 2 fuel cells that would fit were the stock mufflers go and connecting them with -12 line and a vent line like stock connecting them too and maybe putting a shutoff valve between the the 2 cells so when I am racing I can keep less fuel in the tank. I took some measurements and it looks like 5 gallons on each side easily.
    Then put the mufflers mid body and tail pipes, not sure if I want to run before the tires or extend them to the bumper. With the hopes of making the exhaust in aluminum to save weight. If someone can PM a dude on YB to see how much he makes aluminum mufflers for that would be great. I guess I don't have enough posts yet.
    Also what are the thoughts on my 2.5" header collectors? Are they holding me back at 500 hp? And I'm hoping to make more.
    ~Chris
    SCCoA Member #1826
    Dec 2009
    699
    Looks faster already
    Which car is this Chris?
    03' mustang, scu 4.3 with a turbo. 7.0 @ 102mph
    Jan 2003
    Woodbridge, VA
    5,283
    Quote Originally Posted by JT's03 View Post
    The black one with red stripes.
    Dropped this ballast out tonight. Somewhere between 30-40 lbs.
    ~Chris
    SCCoA Member #1826
    21,172
    Chris,
    Do you get much noise/vibration in the cabin with the aluminum diff bushings and that support bracket ?
    Jan 2003
    Woodbridge, VA
    5,283
    Not that I've noticed. It rarely gets driven on the street but when the street tires are on its smooth.
    I think you are fine with doing anything you want with the diff mounts. But when you put aluminum subframe mounts on then it gets rough and you can hear everything in the rear.
    95lx on tccoa got all of Siskas old stuff and I rode in the car at carlisle and it is rough and you can hear the detroit locker doing everything. My car is smooth compared to his.
    Not sure how the DLF subframe mounts affect ride.
    Hope you can make it out to carlisle. Whole bunch of different stuff out there to take in.
    ~Chris
    SCCoA Member #1826
    Orem, UT
    5,908
    I am interested in seeing the fuel cell setup you are considering.
    Also hope to check it out at Carlisle this year.
    Hopefully my car will make its debut there. Might not have the engine done but it should be painted by then.
    21,172
    Quote Originally Posted by BLOWN38 View Post
    That makes sense, and the small amount of drive train and road noise I'm hearing now is most likely coming from the new sub frame connectors.
    http://www.sccoa.com/forums/attachme...0&d=1353952366
    NYC
    17,432
    UMHV bushings will isolate more road noise and vibration when compared to aluminum. The DLF setup made a hugs different in keeping the whole rear from moving around. And my original
    bushing came out looking like new
    Jan 2005
    Northern Cambria PA
    1,644
    I am about done with my fuel cell the thing that surprised me is with the extra gas I had to run in the stock tank and all the stuff I pulled off the car from the stock fuel system I shaved off between 60-80 lbs not to mention that all the weight of the new system is behind the back wheels. Figure to see at least 1.5-2 tenths off the 1/4 mile
  2. Replies: 4
    Last Post: 11-19-2005, 10:21 PM
  3. Replies: 2
    Last Post: 05-30-2004, 07:23 AM
  4. ABS operation : slow?
    Last Post: 01-01-2004, 11:08 PM
