Page 5 of 9 FirstFirst 123456789 LastLast
Results 61 to 75 of 124
Thread: Operation 10.0
  1. #61
    May 2003
    Omaha, Nebraska
    6,262
    Quote Originally Posted by BLOWN38 View Post
    Good to hear.
    Now onto the next thing. Enough belt wrap on the crank pulley? Maybe I can incorporate an idler between the crank and alt.
    I have about the same amount of belt wrap on my crank pulley after moving the alternator to the passenger side. I am thinking that in my case I am not turning a blower so I might be ok. Time will tell. If you decide to add a idler pulley post up pictures cuz I might have to do likewise
    Ken
    93 SC Whipple powered 11.648 @ 119.6
    Twin Turbo, air intercooled..yet to see
  2. #62
    Jan 2003
    Woodbridge, VA
    5,283
    Yeah turning the blower is what I'm worried about. I was hoping I could move the alt back to use the tensioner for the jack shaft and just make some easy solid alt mounts.
    Think I could make a C type bracket for the alt and mount a idler to that and tie it to the WP stud too.
    ~Chris
    SCCoA Member #1826
    Bettie Riding jack stands
    SCARlit on drag duty now
  3. #63
    Jan 2003
    Woodbridge, VA
    5,283
    Probably do something like this.
    ~Chris
    SCCoA Member #1826
  4. #64
    May 2003
    Omaha, Nebraska
    6,262
    Thats what I was figuring I would have to do. For now I will run it the way it is to see if there is a problem. Without a blower to run I might be OK. Anyway post pictures of your solution as it might be something I do as well
    Ken
  5. #65
    Mar 2010
    Grafton, OHIO
    679
    Doh I was missing something! I missed that you were running the jackshaft with the accy belt.
    I think the idler will probly b required. With out the load of the blower, no problem, but the blower is a LOT of load.
    Adam
  6. #66
    Lakeville, MN
    13,517
    It can't hurt to increase the wrap. The main thing to consider when building such a bracket is optimizing the position so that a common belt size can be used.
  7. #67
    Jan 2003
    Woodbridge, VA
    5,283
    If I can successfully run the alt off the jackshaft I was thinking of using something like this. To remove the original accessory drive and maybe change boost too. I would really like to get rid of the blower tensioner in its factory location. And jackshaft for that matter.
    ~Chris
    SCCoA Member #1826
  8. #68
    Jan 2003
    Woodbridge, VA
    5,283
    Quote Originally Posted by Mike8675309 View Post
    Yeah I might have to lop off 1 rib if i go back to the stock jackshaft pulley as there isn't much in a 7 rib design, but plenty in 8 rib.
    ~Chris
    SCCoA Member #1826
  9. #69
    21,173
    Chris,
    Is there any reason you can't move the alternator forward and run it off the accessory drive portion of the crank pulley ? What is the reason for adding the alternator to the supercharger drive belts ?
  10. #70
    Salem OR
    7,517
    If I can successfully run the alt off the jackshaft I was thinking of using something like this[/IMG]
    For what all that weighs, why not just dump the alternator and run a total loss system - only has to last a few minutes, right?
  11. #71
    Jan 2003
    Woodbridge, VA
    5,283
    Chris,
    I can I was just hoping to use the tensioner system already in place. I'm not seeing any good places for a turnbuckle type tensioner at the moment with the low mount idea.
    KMT
    I still like running the car and don't want to deal with charging the battery all the time.
    ~Chris
    SCCoA Member #1826
  12. #72
    Salem OR
    7,517
    If you mean as a DD, yes, even with redundancies that could get old outside of the random competition, I'm sure.
    But hey, no one said a 10 was all have-cake-and-eat, so....
  13. #73
    Jan 2003
    Woodbridge, VA
    5,283
    Not DD but car shows and such.
    ~Chris
    SCCoA Member #1826
  14. #74
    Madison, Ohio
    17,697
    No way that crank belt wrap is going to cut it. Leave the stock JS pulley alone and make up something for the alternator to run off the acc drive. You need to keep in mind that this thing is going to make 25psi boost.
    Email me here.
  15. #75
    Jan 2003
    Woodbridge, VA
    5,283
    Oh its in mind.
    ~Chris
    SCCoA Member #1826
  2. Replies: 4
    Last Post: 11-19-2005, 10:21 PM
  3. Replies: 2
    Last Post: 05-30-2004, 07:23 AM
  4. ABS operation : slow?
    Last Post: 01-01-2004, 11:08 PM
