BLOWN38
My pan cleared the starter that I used so my pan was good to go. You said you are going to boost your engine? Can you still use that EFI set up?? When I was putting mine together the only EFI that would work with boost was the FI Tech set up.. Did they redesign your system?? Just asking and by the way now FI Tech has put their monster setup out that is good to 1600 hp that was still in the test stage when I got my stuff from them....Rich
It has a 2.5 bar MAP sensor so spose to be good to 21 psi and 8 120# injectors. That'll hopefully get me fairly far.
How's your setup doing?
