Results 1 to 9 of 9
Thread: Throttle body removal
    May 2012
    La Quinta, CA
    265
    Guys,
    How do the throttle cable and TV cable come off without breaking anything? I see a metal clip on one and not sure on the other. I'm going to replace the pass side valve cover gasket and it seems that taking off the TB is necessary.
    Thanks
    Mar 2006
    San Jose, Ca
    1,806
    i'm pretty sure the inlet plenum needs to come off too so might as well remove TB, plenum and blower all as 1 unit
    but as for the throttle cable you just pull it off the throttle blade linkage ball attachment...I am not sure about kick down cable as I dont have auto
    then unbolt the 2 10mm bolts holding the cables to the side of the inlet plenum
    Jul 2004
    Hamilton NJ
    2,022
    They just push off and on....the bottom is easier ya just push
    it off the pivot ball...
    Give it a whirl or if a little tight maybe use
    a flat head also.
    Tom
    Tom Downs-member#2752
    MPX'd 90 SC Auto~bought Feb. 2012
    RIP MOM!!! I will always miss and think about you 4Ever! 1940-2018
    RIP Rexy boy!!!! Miss my dog 2006-2018
    http://www.sccoa.com/forums/garage_v...vehicle&id=424
    May 2012
    La Quinta, CA
    265
    Thanks guys,,,flathead sc did the trick. Also, for the AT guys like me, there is a metal clip that hold the TV cable to the bracket. It just pulls up but don't lose it or you will be S.O.L. LOL..
    Orem, UT
    5,902
    Get one of these: Ford part # F3SZ-7H303-B
    It could save your transmission. Mine almost burned up because the rubber grommet wore out and my transmission wouldn't shift or grab. I idled a mile to my house with the 4-ways on. Luckily I wasn't out of town.
    Scott Long
    1992 SC 5-speed
    May 2012
    La Quinta, CA
    265
    Scott,
    Can you post a picture of how yours is attached? My car is totally stock and I don't see how it would attach. I have a 1995 SC AT
    Thanks
    May 2012
    La Quinta, CA
    265
    Apparently, that part only works from 89-93 AOD cars.
    Orem, UT
    5,902
    You said TV cable so I assumed it was an AOD not a 4R70W. You don't have a TV cable.
    Scott Long
    1992 SC 5-speed
    May 2012
    La Quinta, CA
    265
    It sounded like you were saying that all SC's had that bushing / clip upgrade setup. I guess I misunderstood your post...my bad.
  1. BBK/Edelbrook 70mm SC Throttle Body
    By Jimmy 2Coupes in forum Parts for Sale
    Last Post: 01-11-2005, 11:55 PM
  2. Throttle Body TPS question
    By fastfordfan1 in forum Technical Forum
    Last Post: 12-31-2004, 02:42 PM
  3. Throttle body/ air meter on 94 SC?
    By Mark B. White in forum Technical Forum
    Last Post: 11-18-2003, 08:54 PM
  4. Throttle Body Installation...
    By sctbird91 in forum Technical Forum
    Last Post: 03-18-2003, 08:16 PM
  5. Throttle body hose
    By Seshead in forum Super Coupe Club of Ontario
    Last Post: 05-15-2002, 11:49 AM
