Selling a 90 Thunderbird super coupe 5 speed. The car has 124,000 miles. Very low for a 22 year old car. Car is lowered 2 inches and has very good tires. The car makes 220 HP at 315 foot pounds torque. The car is in my name registered in November and smogged. THE BODY IS ABSOLUTELY STRAIGHT NOT ONE DENT!!! LIMITED SLIP DIFFERENTIAL, INDEPENDENT REAR SUSPENSION.
Cons: second gear grinds when shifting at high RPM.needs an allignment still very drivable. one rim is a stock thunderbird rim, other rim is broken beyond repair but will throw it in the tire is still good on the broken rim. summit sells a replacement rim for $149 so all will match.
Mods: 8mm ford motor craft spark plug wires, aluminum radiator, lowering springs, magnaflow muffler, key less entree with a sensitive alarm.
History of repairs:
Mileage---- Service
91845----- Front Brake Rotors, Calipers, Pads
103,194---- Clutch, Pressure plate, Throw out bearing, Slave Cylinder, Resurface Flywheel, Rear main seal, upper control arms
103,525---- Rebuilt Master Cylinder, and ABS Unit
105,175---- New Aluminum radiator, lower radiator and bypass hose
106,038---- Replaced power steering high pressure hose
107,532---- New fuel pump, fuel tank, Rebuilt ECM (computer) by ford dealer
109,554---- Replaced heater core, AC accumulator, speed control brake switch
110,091---- New battery
123,000---- Full tune up: New platinum spark plugs, rebuilt super charger, rebuilt shifter, air filter, fuel filter, oil change, heater hoses, magnaflow muffler
I have all the receipts to prove that all the repairs have been done
Car is located in Sacramento CA area
selling for 2,100 OBO im in need of a truck ASAP
Will trade for a Jeep, truck, toyota,bronco, s10, ranger, anything that can tow a decent load. NO v8s
Call or text Chris at (916) 247 2502
History of repairs:
Mileage---- Service
