Results 1 to 10 of 10
Thread: Wire connection point needed
    Oct 2012
    Lynden, WA USA
    222
    Hi again,
    I have a loose Lt green / yellow striped wire that I have deduced is the temp sensor to the gauge. The wiring diagram seems to indicate this, but so does my non-operable temp gauge!
    Where does that clip end belong?
    Thanks,
    John
    Dallas, TX
    5,695
    The temp gauge sender has a single wire and runs around back of the injector rail, through the bundle on the top of the engine, and over through the passenger side firewall. Where on the car is this located?
    Apr 2005
    Nor Cal
    2,976
    I thought the Light Green / Yellow wire was for an illumination circuit.
    - Dan
    Oct 2012
    Lynden, WA USA
    222
    This is on my 1956 F100 project with the 3.8L SC drivetrain. Currently the wire is dropped at the drivers side front fender, but it looks like it could reach the middle of the firewall. However, I have not yet located its landing point.
    My diagram identifies the Lt Grn with Yel strip as the gauge temp sensor. Since my gauge is dead, I am thinking (hoping) that this is it.
    Thanks,
    John
    Manchester, NH
    2,064
    Hood light?????
    The Great unwhite North
    985
    windshield washer pump??
    Sorry just a thought, like other said Temperature sender is a single connector and usually part of the injector harness
    Jan 2010
    Bossier City, LA
    2,221
    Looks like the under hood light connector to me.
    RwP
    Dallas, TX
    5,695
    RwP
    Same thought here.
    Oct 2012
    Lynden, WA USA
    222
    Cool. Not your usual 1956 truck appointment, but why not. What triggers the switch for this light?
    Thanks,
    John
    Jan 2010
    Bossier City, LA
    2,221
    Quote Originally Posted by jclars View Post
    Thanks,
    John
    Tilt switch in the light socket assembly.
    That should be hot all the time on the non-black wire.
    RwP
  1. Ignition Wire Harness help
    By Billabong089 in forum Technical Forum
    Last Post: 10-18-2003, 07:33 PM
  2. Air/Fuel Guage ?Signal Wire?
    By SilverCasket in forum Technical Forum
    Last Post: 05-28-2003, 11:03 PM
  3. 4 wires O2 sensors vs. 3 Wire O2 sensors...
    Last Post: 05-09-2003, 10:19 PM
  4. Wire Problems...Car Wont start!
    By iwannanSC in forum Technical Forum
    Last Post: 04-10-2003, 08:51 PM
