Results 1 to 15 of 16
Thread: Super charger outlet collar wrench?
    Dec 2012
    Lincoln, NE
    25
    I see the outlet collar is supposed to be tightened to 148 ft lbs and requires a special wrench. How does one get around the special wrench problem and still get it tight enough? Anyone try a oil filter strap wrench? I doubt I can get it that tight though. It looks to me like one could build the wrench to turn the collar but hitting that torque reading is pretty much just a guess. That is tight. I have the teflon o-rings on order and don't want to muck this up.
    If all goes according to plan I may be ready to fire this mother up this weekend, of course things never go according to plan.
    Thanks, you guys have been a great help so far.
    91 SC 5sp
    Mar 2006
    San Jose, Ca
    1,806
    i've always use a large pipe wrench on mine and just went pretty tight with it...never broke anything and it never leaked either
    only problem was that the pipe wrench can tear up the collar grooves a bit so be careful
    here is the special tool:
    http://supercoupeperformance.com/par...aspx?partId=94
    Feb 2004
    IA
    4,258
    State your location and one of the local guys with the wrench may stop by or lend you one.
    Honor, Grace and Dignity......Remember these
    East Hartford, CT
    3,471
    This is the collar on the blower top? I cant even imagine how one of the cheesy hook shaped collar wrenches could hold that much torque.
    When I didn't have the wrench I've use a strap wrench and even a screw diver and mallet in a pinch, I'm certain I've never gotten anywhere near 150ft/lbs.
    Get it a tight as you can with the strap wrench as use a little sensor safe red rtv, you'll be fine.
    Brian Oatway
    '94 SC 2.6KB C4 Auto
    9.956 @ 135.12 mph 1.364 60'
    514rwhp/460rwtq
    "Super Uber Club Member" - per Ira
    SCCoA Member # 705
    Feb 2003
    Tinton Falls, NJ
    1,540
    I usually use a really big pair of channel locks, and I wrap a couple shop rags around the collar to prevent the channel locks from chewing up the aluminum.
    Apr 2005
    Nor Cal
    2,976
    Quote Originally Posted by SCrazy View Post
    Ive seen those cheesy wrenches, they dont work very well - but they do have a 3/8 drive that you could put a torque wrench on.
    I use a professional Spanner wrench tool, it holds the teeth on the collar much better than the cheap knockoffs - usually I tighten it by hand with the correct tool, then hit it with a wooden mallet to get it nice and tight.
    I have a few of these in varying sizes .. the black one is used on the SC, its a 4.5" - 6.25" span
    - Dan
    Dec 2012
    Lincoln, NE
    25
    I am in Lincoln, Nebraska. If someone has one they will loan me for a short time I would appreciate it. Willing to place a deposit on it. email is lonn1950@gmail.com
    Apr 2010
    SLO County
    358
    Talking It works.
    Quote Originally Posted by Ddubb View Post
    - Dan
    I use one of those as well. I wrap the collar nut with a rag and us a hammer to knock the nut loose. To tighten... Well let me explain. I weigh a whopping 125. I have a son who weighs 175. I lay across the engine and pull until I start moving. Then He hangs onto me and tries to keep me still. When we can no longer pull any harder its tight.
    We must look pretty funny but it works. So if you weigh about 250 you should be able to do it on your own. My nut has a few nicks from before I perfected the technique.
    OH Ya. I have grown to like the teflon gaskets but a thin coat of silicon also works.
    Feb 2004
    IA
    4,258
    Quote Originally Posted by lfiers889 View Post
    I will be in council bluffs this weekend. If you can meet me at McMullen Ford you can have it for a week or so. Take it back to McMullen Ford when you are done or mail it back to me.
    Dec 2012
    Lincoln, NE
    25
    When?
    What day and time? I am off Friday thru Monday. My cell is 402-304-3365 in case you have any last minute change of plans. I will be wearing a camo field jacket. I should have it running this weekend assuming no major problems arise. Question: I see on your member profile you used a Mk VIII driveshaft, does that require modification or is it bolt up?
    Thanks.
    Feb 2004
    IA
    4,258
    Thanks.
    I will get there around 11 on Saturday. I can drop the wrench off there and tell you who to pick it up from.
    The driveshaft was shortened for my 5spd. Shop in Omaha did it for me. It was about 10 years ago now.
    Jul 2006
    Des Moines, Iowa
    198
    Thats funny.
    Dec 2012
    Lincoln, NE
    25
    Quote Originally Posted by BirdofPrey97 View Post
    I plan on being there. Thanks again.
    Feb 2010
    Orwigsburg, PA
    29
    I've always taken a small hardwood block and tapped it tight with a hammer. make sure the threads are clean and have a small amount of oil on them. I never had a leak problem using this method. No gouges or scratches on the nut.
    Feb 2004
    IA
    4,258
    I tried reaching you at the number above, but didn't get an answer. If you still need the wrench let me know.
  1. Super Charger Bearing noise
    By uwillbow2me in forum Technical Forum
    Last Post: 05-11-2007, 11:58 PM
  2. super charger
    By 89BBOfSins in forum Want to Buy
    Last Post: 01-18-2006, 05:43 PM
  3. Super Charger questions
    By Yenko in forum Technical Forum
    Last Post: 11-15-2005, 10:18 AM
  4. Super Charger or Rod Noise???
    By ttabol in forum Technical Forum
    Last Post: 01-29-2003, 09:56 PM
  5. Super charger question...
    By 89sc5spd in forum Technical Forum
    Last Post: 07-08-2002, 06:04 PM
