Results 1 to 15 of 27
Thread: Radiator Mounted Electric Water Pump
    East Hartford, CT
    3,468
    I'm thinking about going with a radiator mounted electric water pump.
    I'll make up a blockoff plate for the timing chain cover then mount an electric pump on the radiator tank where the outlet currently is. I think there are a couple of people with remote inline pumps but I'm not sure where they are mounted.
    Does anybody have any experience with radiator mounted pumps?
    http://www.meziere.com/ps-1176-1144-wp362.aspx
    Brian Oatway
    '94 SC 2.6KB C4 Auto
    9.956 @ 135.12 mph 1.364 60'
    514rwhp/460rwtq
    "Super Uber Club Member" - per Ira
    SCCoA Member # 705
    Sep 2004
    Indy
    5,623
    One of my friends works at C&R Racing who builds radiators for those in abundance. If I can't get a timing cover mounted pump to work I'll be going that route, too.
    1994 SC
    4.5L Twin Turbo SVO
    Project GTFD
    East Hartford, CT
    3,468
    Quote Originally Posted by CMac89 View Post
    I cant find a timing cover mounted pump with the right spacing on the discharges except for the Morana one that is like $800.00. If you find one soon please let me know.
    Brian Oatway
    514rwhp/460rwtq
    SCCoA Member # 705
    Jan 2003
    Woodbridge, VA
    5,145
    I've been using one of these for years. no problems with it. I just need to make a plate for the front cover. Guess its something I shoulld try again now that I have a TIG.
    http://www.summitracing.com/parts/em...bk34/overview/
    Photobucket is being a b***h right now I'll get some pics later.
    ~Chris
    SCCoA Member #1826
    Bettie Riding jack stands
    SCARlit on drag duty now
    Jan 2003
    Woodbridge, VA
    5,145
    Here is my first attempt at a cover plate. I think it would have worked great if the plate was thicker. It leaked like crazy. What I originally did was just gut the stock WP cut the impeller off. What that did was throw all the incoming water to one side of the engine. So I had like 50* temp swings for when the fan would come on. The engine temp would go to like 210 then the fan would kick on and the engine would cool to like 150 and just keep cycling like that.
    Road Hawg had a stock pump modified with a splitter to distribute the water to both sides. There are picks here somewhere.
    I also routed my inlet hose behind the belts so if the serp belt ever needs to be replaced you don't lose coolant. And have to mess with bleeding. When I can get photo bucket to display links I'll get picks of the stewart pump mounted.
    Kevin Leitem made a plate similar to what I have here. Thats what I modeled mine from. He used thicker material.
    ~Chris
    SCCoA Member #1826
    East Hartford, CT
    3,468
    I was thinking of a plate like that...I have some 3/8 that I can make it from with a -16 fitting at each side with 2 -16 lines from the pump. If you have pics I'd definitely like to see how the pump is mounted
    Brian Oatway
    514rwhp/460rwtq
    SCCoA Member # 705
    Jan 2003
    Woodbridge, VA
    5,145
    Think i got this. Pump is just held there by the hoses.
    ~Chris
    SCCoA Member #1826
    Jan 2003
    Woodbridge, VA
    5,145
    Here is Todd's setup.
    electric wp
    ~Chris
    SCCoA Member #1826
    East Hartford, CT
    3,468
    Thanks Chris...those pics definately help.
    The water pump mod looks like alot of work......I'm thinking a flat plate with a coupld of AN lines would be easier.
    Holy cow those electric pumps are spendy?
    Did you go with the 55gpm over the 35gpm version?
    Also an interesting note about the coolant hose routing, especially for guys like David Neibert who are always fighting cooling capacity. The main cooling circuit runs from the crossover in the intake through the T-Stat then to the radiator and back to the pump. There are two other circuits that bypass the radiator entirely. One from the t-stat housing directly to the water pump, the seconds from the passenger side of the intake out to the throttle body, heater core, oil cooler then back to the pump.
    The main circuit flows all its coolant through 3 small openings in the t-stat, while the two bypass circuits are 5/8" or 3/4" and are wide open. I would say that more than 50% of the circulated coolant bypasses the radiator. Perhaps rerouting one of the bypass circuits through the rad would help with some extra cooling.
    I don't know why the upper and lower radiator hoses are so big, with the flow restriction of the t-stat they are certainly much larger than needed for flow?
    Brian Oatway
    514rwhp/460rwtq
    SCCoA Member # 705
    Jan 2003
    Woodbridge, VA
    5,145
    I don't think it would hurt to run the bypasses back to the rad. And for the rad fittings being so big I guess its kinda like having a huge blower inlet and an open exhaust.
    The reason the bypasses go to the WP is most likely for emissions to let the engine warm up faster. Like if you look at the newer mod motors they completely cut out the rad till the engine warms up.
    ~Chris
    SCCoA Member #1826
    Madison, Ohio
    17,574
    Quote Originally Posted by BLOWN38 View Post
    Some people run without bypasses at all, a lot of racers come to mind, but this is bad practice if you run a thermostat. The purpose of a bypass is to make sure water is circulating within the motor during warmup to prevent hot spots and possible resulting damage. If you run a thermostat at all, then it should be considered mandatory to run a bypass as well.
    Of course I can't comment on the volume you might need in a bypass, it could be that the OE bypass is on the large side.
    Email me here.
    East Hartford, CT
    3,468
    Do you think drilling some holes in the tstat would suffice to keep some water moving. Maybe (4) 1/4" holes around the perimeter or something?
    Brian Oatway
    514rwhp/460rwtq
    SCCoA Member # 705
    Nov 2004
    butler pa
    1,926
    From the sounds of things i am guessing that you said screw the emissions test. If you did, screw the bypass and thermostat.
    https://www.youtube.com/watch?v=7bNS...e_gdata_player 10.070 video
    Best ET to date 10.070
    Best MPH to date 130.51
    best 60' to date 1.312
    MPX blower/ NO NITROUS!
    Aug 2005
    Chesapeake, VA
    1,976
    Too bad Mike Tuck did not do the electric water pump group buy.
    http://www.sccoa.com/forums/showthre...ght=water+pump
    Jan 2003
    Woodbridge, VA
    5,145
    The part number for mine is E389A-R14. Which I guess they don't have red anymore. So it is 55gpm.
    ~Chris
    SCCoA Member #1826
  2. Water pump pulley fell off today...
    By XR7Kurt in forum Super Coupe Club of Florida
    Last Post: 03-25-2006, 06:38 PM
  3. Electric water pump question??
    By tim in forum Technical Forum
    Last Post: 04-12-2005, 04:56 PM
  4. Best Water Pump??
    By FastBird91 in forum Technical Forum
    Last Post: 02-05-2005, 11:21 PM
  5. Need Help Quickly.. Water Pump
    By XR7 in forum Technical Forum
    Last Post: 04-29-2003, 09:37 PM
