Results 1 to 6 of 6
Thread: Fan thermostat w/relay kit
    Oct 2010
    Mesquite Tx
    173
    My radiator fan does not come on at temperature, and the wiring is all messed up. I don't feel like dealing with the problem so am just gonna install a thermostat fan relay with switch. In these kits it comes with a thermostat that screws into the engine somewhere to allow the fan to come on at temp. Where is the best place to screw or mount this thermostat?
    Jul 2003
    Eastern (nee Western) PA
    4,993
    Quote Originally Posted by Rezid View Post
    You can buy a T-fitting to put into the upper radiator hose.
    I would recommend fixing the wiring and testing the IRCM. The factory 2-speed fan is a good system.
    God bless!!!
    Former Birds:
    Oct 2010
    Mesquite Tx
    173
    I don't think the fan is factory, plus I think I will be easiest to go this way. Thanks for the info!
    20,946
    Most of those fan relay kits, come with a temp probe you jam into the fins of the radiator.
    Oct 2010
    Mesquite Tx
    173
    It comes with some sort of bung that the temp sensor screws into. I don't see how you can jam it into the radiator fins?
    Jan 2010
    Bossier City, LA
    2,219
    They come both ways - radiator probe, or water jacket sensor.
    Do you have the EATC? Do you need the cold engine lockout? If "No" to either, then there's the bung or sensor for that which you can pull, leave the CELO wire disconnected, and use that hole for the radiator fan controller.
    RwP
  1. Rounded Fan Clutch Nut
    By RoundHead in forum Technical Forum
    Last Post: 04-14-2013, 01:47 AM
  2. Cooling Fan Motor Trouble.. Help....
    By BArtkowsky in forum Technical Forum
    Last Post: 05-14-2007, 12:41 PM
  3. Cooling fan turning on late
    By kenshi in forum Technical Forum
    Last Post: 06-17-2005, 12:46 PM
