Thread: new fan motor
    Sep 2012
    nashville tn
    362
    new fan motor
    I just received my new fan motor and I am having a hard time getting the motor to seperate from the blade,the shaft goes to the end then it is flush with the fan,doesn't seem to want to go any further than that,is there a trick to getting it out of there without damaging the fan which is plastic. thanks
    Oct 2003
    Allentown, PA
    907
    Naah... You do not take the motor and fan apart!
    I wrote a how to article at tccoa way back when but someone deleted it.
    In a nutshell: You use a drill and bit to drill out the rivets that hold the motor to the shroud. Use a center punch on the end where the rivet is the largest to help start the hole. Start with a small drill bit and work your way up. Use oil to keep things cool. It will be a pain, you have to be careful as it will take a little time but it is better than buying a whole new fan shroud assembly.
    Replace the rivets with 18-8 SST bolts (the largest fine threaded ones that fit in the hole), washers and heavy 18-8 nuts. Use Loctite on the threads to keep it together. I think I used red. Not sure though...
    I think, it was at least eight years since I did it on the Cougar and the Loctite is still holding.
    J.Miller
    1990 XR7 and 1955 F250!
    Sep 2012
    nashville tn
    362
    didn't have to drill anything it was just wedged in there pretty good,sprayed some silicone in there let it sit and it popped right out no problem.
  1. Replies: 3
    Last Post: 06-24-2012, 01:42 PM
  2. Cooling Fan Motor Trouble.. Help....
    By BArtkowsky in forum Technical Forum
    Last Post: 05-09-2007, 09:34 PM
  3. Smoked fan motor after Adj. T-stat install
    By factoryblue in forum Technical Forum
    Last Post: 02-11-2003, 01:50 AM
