Results 1 to 5 of 5
Thread: Little gears at rear axle
    Oct 2012
    Lynden, WA USA
    222
    Searched online, but no luck - what are the little gears on either side of the rear end housing. Attached are a couple of sensors of some sort.
    I am considering deleting these as not useful for my Ford truck / 3.8L SC project.
    Safe to eliminate?
    Thanks,
    John
    Jan 2010
    Bossier City, LA
    2,204
    The ABS tone rings.
    Sorry, first line posted from my phone, so I was a bit terse.
    Unless I miss my guess, you're talking about the ABS tone rings and the ABS sensors.
    And they're not on the diff, they're on the halfshaft (the tone rings). And the sensors don't attach to the tone rings, but to the diff.
    Safe to eliminate? I suppose, but why? Most anybody making replacement halfshafts will include them.
    OTOH, if you're bringing over the Teves Mk II ABS, you'll need them.
    RwP
    Oct 2012
    Lynden, WA USA
    222
    Thanks Ralph. I am eliminating the entire ABS system. looking to strip down as much as I can to relieve the truck frame from all that wire!
    John
    Sep 2006
    NE, AR
    1,570
    I'd leave the gears and just pull the sensors.
    Oct 2012
    Lynden, WA USA
    222
    sounds like a plan. More concerned about getting excess wires deleted, now that I know the engine functions without the ABS functions. Also looking at deleting the auto adjust shock wiring, as I wont have need for that either.
    John L.
  1. rear end gears
    By slowpoke in forum Technical Forum
    Last Post: 10-19-2007, 05:44 AM
  2. Stock AOD rearend gears/ stock 5speed rear end gears
    By shawpdx1 in forum Technical Forum
    Last Post: 08-14-2007, 08:25 PM
  3. Continued ABS woes (and others)
  4. who puts 3.73 rear gears in a 90 5 speed?
    By kwikcoupe in forum Technical Forum
    Last Post: 03-01-2006, 12:14 AM
  5. Ford Racing Rear w/ Gears
    By ThunderCoupe94 in forum Non Technical Forum
    Last Post: 12-22-2003, 10:04 PM
