Results 1 to 5 of 5
Thread: Won't Idle = why
    Nov 2011
    110
    Won't Idle = why
    I took the engine out of a 90 RX7 and it ran grate so I instaled it in a 9o SC and now it will not idle. It acts like it is idleing so low that is dies. It seams to run ok when you bring the idle up to 1300 rpm or more. IT reves up good also. I tried to checking for vac leaks by spraying starting fluid at the lines and the intercooler tubes but I can not find any leaks. I also tried switching the computers between the two cars and still won't idle. I used every thing out of the RX7 so all the sencers should be ok seeing that it ran good in RX7. I went ahead and tried switching out the idle control valve and still won't idle.
    Where do I go from here Help please
    May 2008
    san lorenzo
    1,515
    cel
    do you have a check engine light on?
    how about the maf sensor if it's dirty can cause this too..
    have you tried to pull some codes?
    1989 t-bird sc auto
    1992 t-bird sc 5 speed
    1995 t-bird sc 5 speed
    all stock but getting together some parts so i can have more fun!....
    Jul 2004
    Hamilton NJ
    2,022
    Gotta be a major vacuum leak somewhere!!! Sounds like
    same as mine was doing when my vacuum gauge was
    only reading 10-11 of vacuum!!!
    BTW....ITS an XR7
    Tom
    Tom Downs-member#2752
    MPX'd 90 SC Auto~bought Feb. 2012
    RIP MOM!!! I will always miss and think about you 4Ever! 1940-2018
    RIP Rexy boy!!!! Miss my dog 2006-2018
    http://www.sccoa.com/forums/garage_v...vehicle&id=424
    Manchester, NH
    2,064
    Quote Originally Posted by 89XR7TD View Post
    BTW....ITS an XR7
    Tom
    X2 to tha vacuum leak.
    Nov 2012
    Percy, Il
    118
    Ya I may also just because its easy, run around and ground some stuff out.. I had an s10 did this same crap to me all the time. I just put a chassis ground to the engine, dash, and harness and never had another problem w it.. I always plan on dealing with bugs like that when doing a swap.. Good luck! I hope you figure it out!
  1. Seems like engine cuts out at idle, no CEL though, HELP!!!
    Last Post: 07-24-2010, 08:49 AM
  2. Need serious help here, low vacuum, running rough.
    By spelch in forum Technical Forum
    Last Post: 02-19-2005, 05:05 AM
  3. Idle Re-learn Proceedure
    By discipled1 in forum Technical Forum
    Last Post: 01-18-2005, 08:31 AM
