Thread: Rear suspension question
    Oct 2009
    Spokane Wa
    1,209
    So... how close are the rear suspensions to the cobra mustangs.
    We see diffs swapped, hubbs but are the control arms the same also?
    i see kenny brown is now offering rear lower control arms (that use a coil over shock set up) and new upper arms that are supposed to correct some problems with the cobra rear suspension.
    just wondering.
    Apr 2003
    Ventura, CA
    1,753
    The control arms are not interchangeable.
    Mar 2010
    Grafton, OHIO
    624
    On another thread, I can't find it now, Dave Neibert posted a link to the company whose rear dif rear mount he uses. They showed tubular lower rears for the t-birds for use with coil overs I think. I also suffer from CRS so don't remember the company name either, maybe Dave will see this and chime in. They were $700 I believe, never seen anyone on the forum mention using them.
    Adam
  1. Rear suspension overhaul
    By DemonSC in forum Non Technical Forum
    Last Post: 08-30-2011, 11:01 AM
  2. rear shocks spring question
    By AutobotGears in forum Super Coupe Club of Ontario
    Last Post: 08-05-2008, 05:12 PM
  3. Another rear suspension question.
    By Mike Puckett in forum Technical Forum
    Last Post: 11-28-2007, 03:16 PM
  4. rear brake upgrade question
    By hellakornhaus in forum Technical Forum
    Last Post: 07-28-2005, 12:59 PM
  5. rear suspension bump stop question
    By blown96bird in forum Non Technical Forum
    Last Post: 05-19-2005, 12:41 AM
