HwyStar
You got me on the math! Finished that at about 10p... Yeah, i understood i would get a wipe pattern, thats not the problem. It did get narrower as i shimmed, which is good. Just wasnt sure if the wipe was good where it is. Its a little high. The rocker was sitting low which was causing a wide high wipe. I think this might be the problem with reground cams, the base circle is smaller which means the pushrod has to be longer to make up the difference.
