thunderchikinsc
Hi guys, I just bought a 90 sc 5spd for 1500$ I've had thunderbirds before but nothing built like this. Was it a good deal and what kind of power do u think it should make?
Griffin Radiator
73mm C&L MAF
70mm BBK Supercoupe TB
10% overdrive pully
ASP Underdrive pulleys
Intercooler Fan w/ temp sensor
Raised Blower top
95 S-Blower
New Jasper engine was bored out .02
Cometic head gaskets with arp hardware
Jacobs wires
48lb injectors
K&N 9" cone filter with ram air box
Upgraded headlight kit. Competition Limited 360 watt kit
Dual Pod Auto Meter Gauges on A-pillar. Air/Fuel Stoich meter, and Boost pressure gauge (Both Auto Meter products) Centerforce Dual Friction clutch newly replaced.
2.73 gears stock changed to 3.73's (still on hand for outright sale) but the car now has 3.27's and they really work well with the setup. Clutch hydrolic slave cylinder replaced and also new hose connecting to trans. Eibach Progressive Rate Lowering Springs 1.5" lowered.
Tokico Illumina II shocks
IRS bushings thru MN12 Performance.
All urethane bushings replaced thru MN12 performance.com KVR Performance Cross Drilled Rotors all 4 (Stock size rotors). Stock calipers.
New e-brake cable. This is a hard part to find anymore. Much searching went into getting hands on a new cable. MN12 Performance Dual exhuast with mandrel bent tubes.
Dynomax mufflers
Magnacore Resonator
Addco Rear Sway Bar 1.5” or 1.75” don’t remember. 245/50/16s. New tires Stock wheels in good condition.
Cervini's Ram Air hood and Cervini's Rear spoiler. Viper Alarm system. Top of the line 4 button system when purchased new ($800)
Griffin Radiator
73mm C&L MAF
10% overdrive pully
Raised Blower top
95 S-Blower
Jacobs wires
48lb injectors
Dynomax mufflers
Magnacore Resonator
