Originally Posted by
Osprey
OK the car was trying to run hot at any constant speeds above 65mph. Being aggravated and not wanting to blow a head gasket I replaced the entire cooling system... Rad, Thermostat, water pump, switch and temp sensor. The car runs great now at speed but if I am in traffic, A/C off the car still heats up to the full right side of the normal band before it starts the fan and cools it to the middle. I am not comfortable with it getting this hot before the fan kicks in. Should I just buy an aftermarket switch to turn on at 180deg? I have no idea why they would design this to run so hot with known head gasket issues? By the way it had a 195deg thermostat in it and I replaced it with a 165deg one.
Check your first post. "The cooling fan does not come on in low." There's your first problem. Ford didn't design the car to heat up all the way to the right side of the normal band. They designed the car to turn on the low speed fan just over the designed thermostat temperature, so that it would run at the designed temperature. Your low speed fan doesn't work, which lets the car get pretty hot before the high speed fan kicks in and pulls it back down. Fix the low speed fan or fan circuit and you will fix your temperature problem.
As for the 165 degree thermostat, you can see it isn't helping. First of all, the radiator isn't shedding enough heat in traffic because of a lack of airflow, so the open thermostat is kind of pointless then. And when you are cruising at high speed, the open thermostat may be letting the car get too cool. That puts the car back into open-loop warm-up mode, which makes it run rich and hurts your fuel mileage. And running at 165 is detrimental to the life of the piston rings and other metal components in the engine. They wear best right around 200. Which, not coincidentally, is right where Ford designed the engine to run. So, once you fix your cooling fan issue, change the thermostat back to stock and the car will run better.
God bless!!!
Former Birds:
