Results 1 to 5 of 5
Thread: Pulled codes
    Apr 2005
    Canton, OH
    631
    Pulled codes
    Hey guys, I just got my code reader in today. My CEL wasn't on but I decided to check it out anyways, and it pulled these codes. Anyone know where to point me? I'm hoping whatever this is will fix my loss of power i've been experiencing
    211: Profile Ignition Pickup (PIP) Circuit Fault
    214: Cylinder identification circuit failure
    21,093
    Quote Originally Posted by Cuztom Dreamz View Post
    Those are probably stored codes from when your balancer was broken. Remove the negative battery cable for about 5 minutes to clear codes, then reattach cable and check the codes again. If everything is okay you should get code 111.
    Apr 2005
    Canton, OH
    631
    Thanks David i'll try that right now. The first code that came up was 111 not sure if that matters but 211 and 214 followed. I'll hook it back up here in a few minutes and check again.
    Apr 2005
    Canton, OH
    631
    Ok cleared the codes by removing the neg cable, now i just get 111 on KOEO.
    Jumped to KOER, and I get this:
    538: Insufficient RPM change during KOER Dynamic Response Test
    Apr 2005
    Canton, OH
    631
    Oops that was my bad didn't run the throttle at the mark apparently, complete pass!!
  1. Pulled Codes...Please Help..!!!!
    By tattoo in forum Technical Forum
    Last Post: 06-30-2006, 10:38 PM
  2. Pulled Codes, Running Lean?
    By matteo in forum Technical Forum
    Last Post: 04-03-2005, 05:25 PM
  3. Pulled 2 codes
    By CMac89 in forum Technical Forum
    Last Post: 04-02-2005, 02:05 PM
  4. Pulled Codes...49...??
    By 007_SuperCoupe in forum Technical Forum
    Last Post: 12-07-2003, 09:46 PM
  5. Pulled codes...Cant hold IDLE
    By Bigme574 in forum Technical Forum
    Last Post: 09-10-2002, 02:11 PM
