Results 1 to 6 of 6
Thread: 89 sc idle problem
    Jan 2013
    7
    89 sc idle problem
    Car idles at 500 rpm consistently, and lacks power when any load is put on the engine.
    Already replaced: IAC, Ignition control module, Spark plugs/wires, coil pack, ALL engine gaskets (intake, head, TB etc.)
    Heres a video:
    http://www.youtube.com/watch?v=3POp5...ature=youtu.be
    Dallas, TX
    5,654
    Check for collapsed motor mounts... and no Im not joking. Id recommend the solid rubber replacements.
    Feb 2004
    IA
    4,252
    245,000 on the clock. When was the last time anything was rebuilt as far as the engine, blower, clutch?
    Honor, Grace and Dignity......Remember these
    Jan 2013
    7
    Well, the clutch was just replaced, and we also just replaced the head gaskets after we did the clutch.
    Jan 2013
    7
    The guy who owned it before us had already replaced them to solid engine mounts. And that really isn't the problem anyway.
    Thanks for any advice you can give us. God bless.
    20,902
    Suggest checking the fuel pressure regulator to make sure the vacuum hose that attaches to the return plenum is installed. Without the hose installed fuel pressure will stay constant at around 39 psi instead of increasing pound for pound with boost. You can also do a fuel pressure test by attaching a gauge to the test port on the fuel rail.
    You say it doesn't have any power under a load, but it would help if you were more specific. For example does it bogg and just feel poochy when you step on the gas or does it buck and backfire? Are you getting a check engine light ?
  1. Idle Problem & oil leak
    By heirmb in forum Technical Forum
    Last Post: 10-26-2007, 02:12 PM
  2. Idle problem still.
    By 1BADSC in forum Technical Forum
    Last Post: 03-22-2003, 12:01 AM
  3. 75mm Pro-M Idle Problem
    By Boostman23 in forum Technical Forum
    Last Post: 10-26-2002, 03:31 AM
  4. help!!! idle problem
    By bcr2886 in forum Technical Forum
    Last Post: 08-19-2002, 02:57 AM
  5. high idle problem Please HELP
    By Gears in forum Technical Forum
    Last Post: 07-16-2002, 11:13 AM
