Results 1 to 15 of 17
Thread: Fuel pump
    Apr 2013
    LaValle, Wisconsin
    30
    Fuel pump
    My fuel pump went out. What should I get to replace it besides one from the local parts store. Upgrade the fuel pump. The car has long tube headers cold air intake and a 5% jackshaft pulley. It a 93 so I will be putting on a late model superchared on it and other go fast parts. I'm looking to something I can just bolt in. I was looking on supercoupeperformance.com at there fuel pumps. Just seeing what other people's preferences are.
    Jan 2003
    Woodbridge, VA
    5,256
    Get the 255 High Pressure or the Aeromotive Stealth 340 center inlet. Either one you need to change the connector on the cars wiring.
    ~Chris
    SCCoA Member #1826
    Bettie Riding jack stands
    SCARlit on drag duty now
    Sep 2010
    Massapequa Park, NY
    547
    You can get the 255lph walbro kit from supercoupe performance.
    Apr 2013
    LaValle, Wisconsin
    30
    Just ordered the kit from supercoupeperformance know I hope it's no to rusty to get the pump out.
    Manchester, NH
    2,064
    Are you planning on dropping the tank or do you plan on popping up the back seat and cutting the floor. I never thought I would say it but cutting the floor was easy breezy.
    Apr 2013
    LaValle, Wisconsin
    30
    Dropping the tank I have a lift I can use so it not like I'm in a garage on the floor trying to do this and this is the third one Ive done. It kinda sucks I have a half tank of gas too so she's nice and heavy.
    Jul 2003
    Eastern (nee Western) PA
    4,993
    Quote Originally Posted by 93superbirdie View Post
    It's doable without a lift if you are persistent. I have done it once in a driveway. Once in an apartment building parking lot. And once on a residential street. Not fun, but I have done it.
    God bless!!!
    Former Birds:
    Sep 2010
    Massapequa Park, NY
    547
    See I cheated....i bought an entire fuel pump assembly off here and put the 255lph pump into that, so i just have to swap it out when the time comes, a 10 minute job.
    Manchester, NH
    2,064
    You still need to drop the tank or a cut a hole in the floor.
    Apr 2012
    100
    I would rather take a punch in the nose from someone before touching a gas tank, but on my 90 SC after taking a good two months after getting a new pump I plowed in. Two exhaust bolts and some lube to drop the rear exhaust pipes and two tank straps your there.
    Sep 2010
    Massapequa Park, NY
    547
    If only it was that easy for me.....custom 1 piece exhaust lol
    Jan 2010
    Bossier City, LA
    2,295
    Quote Originally Posted by LIVipers View Post
    What size?
    I'd buy a coupler, cut it in a straight, put the coupler on to reattach, and go to the muffler shop and get them to put a ball and socket joint there.
    Note to any reading: Do NOT, repeat, do NOT use a 1-piece exhaust! Put at least ONE coupler in it so you can drop the exhaust and get to the gas tank! Unless you can weld it back up yourself ...
    RwP
    Jul 2003
    4,993
    Let me know when you start working. I will call you 10 minutes later to check on you.
    God bless!!!
    Former Birds:
    Manchester, NH
    2,064
    What size?
    RwP
    Agreed on the exhaust advice. I had two flanges welded on my new exhaust directly in front of the resonator. I did not however have the shop use the ball and socket joint. I had them use flat flanges and gaskets. I fully expect the bolts to seize up on there but it;s easy to cut those bolts where they were placed.
    Apr 2013
    LaValle, Wisconsin
    30
    Well my luck the person put dual exhaust in so it will unbolt easy from the long tube headers. Then it's gettin redone cuz it's rubbing on stuff and it looks bad.
  1. New fuel pump results in boost gain
    By Night Wing in forum Technical Forum
    Last Post: 01-10-2005, 01:40 PM
  2. Fuel Pump Dont Work
    By wingrg in forum Technical Forum
    Last Post: 03-08-2004, 08:39 PM
  3. C code fuel pump ?
    By stocker 89 in forum Technical Forum
    Last Post: 09-15-2003, 02:43 PM
