Precisely. There needs to be just a bit of give to the adhesive. Also why epoxy doesn't hold up. Ive used plain jane silicon rtv and cleaned the glass with brake cleaner and they've held up indefinitely. I've never had to redo one.Whatever you use it must have some flex to it. I tried JB Weld once and it lasted less than a week.
Anyone take any photos of this when they had the door apart to show what it looks like ??
Are you talking about the two regulator attachment points ??
tried epoxy. didn't hold. tried automotive GOOP adhesive, and that didn't hold. i'm going to go to the local pick n pull, and go for the metal clips.
I think we said epoxy wouldn't work. Did you not see that comment? Or did you just need to find out for yourself?tried epoxy. didn't hold. tried automotive GOOP adhesive, and that didn't hold. i'm going to go to the local pick n pull, and go for the metal clips.
I think what we said that would work is Silicon RTV with proper cleaning.
