Results 1 to 15 of 18
Thread: Vacuum/boost hose location
    Jun 2013
    97
    Hey y'all,
    The vacuum/boost gauge quit on my 92 sc, and I'm thinking it's either the hose has come loose, or cracked. I've found the hose at the cluster, but I do not know where it connects at the back of the engine, nor can I see it come out of the firewall to be able to trace it.
    Thank you,
    Jim
    John 3:16
    Jul 2003
    Eastern (nee Western) PA
    4,993
    Quote Originally Posted by 92stockbird View Post
    Hey y'all,
    Thank you,
    Jim
    John 3:16
    Hi Jim,
    It connects to the return plenum where it turns down to enter the lower intake manifold. The connection point is right near the ACT sensor. The hose comes out of a bundle of stuff running along the firewall.
    God bless!!!
    Former Birds:
    Sep 2010
    Massapequa Park, NY
    547
    Does the cluster need to be removed in order to change this hose? Or can I just reach up laying on my back? I need to do this myself today, mine finally cracked beyond repair after 19 years
    Sep 2011
    Mcallen TX
    773
    Quote Originally Posted by LIVipers View Post
    Yes tom i think u need to remove cluster in order to plug a new vacuum hose into the gauge
    Find a spot to route out of the firewall into the engine bay and connect new one to return plenum
    Laying on ur back may be quite uncomfortable and very hsrd to get the hose on there but I never tried that way
    Mine is actually apart on dash since im adding gauges and my wideband so I can take pics so u see where the vacuum hose goes through or if there is space from beneath , ill post em up on fb so u can see
    Sep 2011
    Mcallen TX
    773
    Jim I hope this helps u couldn't find a better pic from there u can follow the small hose
    Sep 2010
    Massapequa Park, NY
    547
    Quote Originally Posted by Miguel5671 View Post
    Awesome thanks Miguel, I had a feeling i would have to remove the cluster, as nothing with these cars is ever easy lol. Although it shouldn't be terrible to do. I just gotta make sure I can pull it through the firewall in the same spot as the original
    Sep 2011
    Mcallen TX
    773
    You are right on that one some so simple is always a pain on these cars lol
    Yes once u remove the cluster its easier to follow the hose/line, I tried following it from the engine bay side but the crimped wire bundle made it hard to follow
    I ran a new line from my gauge that was thinner and made it easier passing through the firewall
    Had this pic on my phone but ill take better ones later on today
    Sep 2010
    Massapequa Park, NY
    547
    I have a thicker, yet more pliable hose, so hopefully i can just push it through and get it to a spot in the engine compartment where it can be grabbed and ran to the return plenum, however only time will tell lol
    Sep 2011
    Mcallen TX
    773
    Should be able to get it
    If u ran a 12v cable for ur audio u can use the same path to get to the engine bay and then route to return plenum if u find that the original spot is too hard to get through
    BUT it will make alot more sense once ur in there
    Sep 2010
    Massapequa Park, NY
    547
    Okay Jim, I just did this this morning, and i have a few bits of advice:
    1) You'll need to remove the drivers side inner wheel-well cover in order to get to the line
    2) There are 2-3 "junctions" underneath the dash that the wire goes to (meaning it isn't one straight piece of vacuum hosing).
    3) It will be very difficult to reuse the factory routing for the line, so I personally would recommend coming through the firewall at an easier location. I personally did this through the hole i made for my LC-1 wiring
    It is about a 2 hour job, mostly because you have to be careful when handling the dash pieces so you dont end up cracking them
    Hope this helps,
    Tom
    Jun 2013
    97
    vacuum/boost hose location
    I had thought the hose ran from that nipple to the gauge. I' am going to do this tomorrow, as we are getting showers, and I don't have a garage to work in. Thank you for the pics, and help.
    Jim
    John 3:16
    Sep 2010
    Massapequa Park, NY
    547
    It does run from the gauge to the nipple,
    However there are a couple of like connectors that go along the length of the hose
    Jun 2013
    97
    From inside the car, we found where the hose routes through the dash, but we are unable to find where it enters the engine bay. Also can't find a hole to run the hose into the car. Where is a good place to drill a hole?
    Jul 2003
    4,993
    As LIVipers alluded to earlier, the hole is there. Take off the fender liner and you should see the hose coming out of the passenger compartment, into the space above the wheel, then into the engine bay.
    The only question is, can you reach the broken part of the line? If it is broken behind the dash, it may be hard to fish a new line through the same routing. If it is broken in the engine bay or inside the wheel well, then there's nothing to it. Just splice with a section of rubber hose.
    God bless!!!
    Former Birds:
    Jun 2013
    97
    The line broke about 2 feet from the nipple inside the engine bay. The hard part is, finding where it broke.
    Jim
    John 3:16
  1. Location of SC-btpass vacuum hose?
    By Kit Sullivan in forum Technical Forum
    Last Post: 02-09-2016, 11:42 PM
  2. 94 SC Ruptured Heater Hose
    By tedallen in forum Technical Forum
    Last Post: 04-22-2009, 04:04 PM
  3. power steering hose interference
    By QuickMustang in forum Technical Forum
    Last Post: 08-28-2008, 01:31 PM
  4. Where is the 'heater inlet' hose?
    Last Post: 12-23-2006, 05:26 PM
  5. bap sensor vacum hose location
    By creeperxr7 in forum Technical Forum
    Last Post: 04-07-2003, 09:19 AM
