Results 1 to 6 of 6
Thread: Speedo gear
    Jun 2013
    97
    Speedo gear
    Got the vacuum/boost gauge patched. Thank you for the pics, and help.
    New question. Where is the speedo gear in the 5spd tranny, and ho do I get to it to check it? The speedo gauge gears are new, purchased from scp.
    Also, what tool is used to remove the "nut" at the top of the supercharger tube to access the pcv valve?
    Thank you,
    Jim
    John 3:16
    Nov 2010
    Jerseyville, Illinois
    323
    the speedo gear is back toward the tail shaft. the PCV valve is actually at the back side of the passenger side valve cover. no need to remove SC tubing. there is a special wrench BTW for the SC nut you can get from SCP. some of us use a big screwdriver and a hammer but that is hard on the slots.
    Jun 2013
    97
    speedo gear
    What is the part that is under the sc tube, in the valve cover, that has a hose attached, and runs to the underside of the air inlet to the throttle body?
    Nov 2010
    323
    that is just a tube adapter that returns air from the crankcase back through the inlet. the air has already been accounted for by the MAF and this is done so that air is not lost.
    Jun 2013
    97
    speedo gear
    Where exactly on the trans is the speedo gear? Is there an electrical connection attached to it?
    Thank you,
    Jim
    John 3:16
    Sep 2012
    Raleigh, North Carolina
    668
    here is the how to from tccoa
    http://www.tccoa.com/articles/gears/speedo.html
    Any idiot can make a Mustang fast...
    It takes a special idiot to make a Thunderbird fast!!!
    89 SC 4.3 stroker 384rwhp 473ftlbs
    Best ET 13.085 Best MPH 106.6... got some work to do!
    2016 V6 M90 Dyno Champ 2016 Mod 1 Runner Up
  1. 21 tooth speedo gear
    By doug93sc in forum Technical Forum
    Last Post: 10-05-2005, 02:07 PM
  2. speedo and rearend gear question
    By x182dan in forum Technical Forum
    Last Post: 02-19-2005, 04:17 PM
