Well, had the first issue with the "95. Was on my way to Oshawa and noticed the temp guage was pegged!!!!!!! Slowly amd my way back home, and after a day I got under the hood to see what was up. Turns out "BOTH" fans are pooched!!!!!!!!!!! The rad fan was actually sitting inside the shroud area loose and the 30amp fuse for the cooling fan was blown. After removal I noticed the pin that holds the rad fan onto the fan motor was missing and, this probably just didnt happen, the cooling fan motor was seized. I havent driven the car in a long time so I guess I need to do so more often. To make a long story short, I got a complete fan, shroud and motor assembly from Doms Wreckers for $150 and a new cooling fan motor thru Napa They will be in tomorrow so wish me luck.
And you guys thought I wasnt mechanical. LMAO Time will tell.
BTW The relay fuses for the distribution box are damned expensive and originals are in short supply.
Matt
Matt
