davec73
I went out last night to smoke test my car and recalibrate the wideband 02. when I turned the key on for the recalibration of the guage the fan and fuel pump cam on and stayed running. After I buttoned everything back up I opened up BE and looked at the configuration and it had a bunch of symbols and useless junk in tune slots 2 through 8, the tune was showing up in slot 1 but nobody was home. I reloaded the tune and turned the key on and everything seemed fine. I went to check it today and the fan and fuel pump came on and stayed on again! Called around a bit and then called moates, if you look on there page they have a special line item for returns in the product listings on the left or RMA. Turns out there was a bad batch of QH chips that have a bad circuit in them somewhere that drains the battery and the chip is bad, you have to go through the rma process and return the chip and they send you out a new one. So If your chip is loosing the tune and has any of these symptoms I would call moates and see if yours is one of the faulty ones, the only way they know is the symptoms of what it is doing.
