wire routing
92stockbird
I found one wire that leads from the stereo to the amp, and sub. I'am unable to find the second wire that goes from the stereo to the amp.
1st question: Where do the connectors from the stereo to amp connect under the dash?
Question 2: How do the wires route from the stereo to the amp? Where exactly, under the dash?
Question 3: I have found one connector in the trunk. The other is missing. Are these wires, and connectors separate?
Question 4: would anyone have these wires for sale?
I want music, but want to keep the stock equipment if possible.
Thank you,
Jim
JOHN 3:16
You can find most the wires from this site... http://www.thunderbirdscshop.com/interior.htm
I also have a 92 and was just out checking the stereo stuff myself. If you want an aftermarket stereo but want the same equipment to hook up to it you will need another piece found here..
http://www.ebay.com/itm/PAC-ROEM-FR...iter_Display:3.8L&hash=item415a339391&vxp=mtr
As far as where it hooks up I'm not sure but in the trunk to dash harness. I think there are two amplifiers one silver on the underside of the subwoofer and another black one that is next to the ABS module under the trunk. (I think???) I am missing that amp and the sub is blown so I just used the bypass and am putting in my own subs and amplifier.
