Results 1 to 11 of 11
Thread: Newbie in Lititz
    Sep 2013
    Lititz,Pa
    29
    Newbie in Lititz
    I just bought this car yesterday. Wow why did I wait so long.Name:  sc bird.jpg
    Sep 2013
    Lititz,Pa
    29
    needs some work
    she needs a lot of work but is still has good bones. My first mod is to add some soap and wax.Name:  sc bird1.jpg
    5,106
    Welcome. The last guy that owned it didn't keep it long.
    http://www.sccoa.com/forums/showthread.php?t=130908
    SCARlet on drag duty now
    Sep 2013
    Lititz,Pa
    29
    old owner
    no he didn't , but he has some cool stuff to tinker with. I brought it home and on the way it started bucking and just shut off going down the road. Two seconds later tach came back up and poof I have power. I think the gremlins have started lol.
    Sep 2013
    Lititz,Pa
    29
    and thank you for the welcoming I am sure I will find a ton of knowledge here.
    Jul 2003
    Eastern (nee Western) PA
    4,993
    Quote Originally Posted by Bryaninpa View Post
    Welcome from PA. Your problem is probably related to a separating ignition switch or a failing DIS module. Car looks nice!
    God bless!!!
    Former Birds:
    1990 SC auto ... red outside, gray cloth inside ... ~225,000 miles ... Sold.
    1990 SC auto ... white outside, gray cloth inside ... ~150,000 miles ... wrecked.
    1989 Base auto ... Crystal Blue metallic outside, dark blue inside ... ~160,000 miles ... Sold.
    Sep 2013
    Lititz,Pa
    29
    dis module?
    I keep hearing about the dis module. What the heck is it? All the cars I ever wrenched on had coil,carb and dist. lol. Off I went. Computers,dis mod dat mod I think I may have quite a bit to learn. I also called about getting a clutch put in. Wasn't ready for a $750 bill for that, but that's the price of having toys I guess.
    Jan 2008
    windsorlocks,ct
    169
    it is called an ignition module, and it sits on top of the ac compresor right in front of the oil cap. it is grey in color and has a connector on each side. our cars have a distributless ignition system, crank sensor and cam sensor and the ignition module coincide with one another, use the search function, it will help you a lot.
    Sep 2013
    Lititz,Pa
    29
    ign mod
    Thanks for describing to me exactly what I am to be looking for when I pop the hood .I just want to make sure this is the part number I need. Motorcraft DY1075. If anyone could shed some light that would be a great help.
    Jul 2003
    4,993
    Can't guarantee it. I would suggest either asking an auto parts store to test it or ruling out the ignition switch first. Also, are there any trouble codes?
    God bless!!!
    Former Birds:
    Sep 2013
    Lititz,Pa
    29
    well today I took her to the garage. The clutch was on its last leg so going to have that done along with pressure plate. throw out bearing. also decided to have the slave cylinder replaced as well. since the mechanic is in that far I figure why not check the rear main as well
    As for codes the light comes on and then goes out within a minute or two. I will take the module to get tested when the car is back home.
  1. newbie with new code reader
    By Chris Ashford in forum Super Coupe Club of Ontario
    Last Post: 06-20-2012, 11:51 PM
  2. SC newbie?
    By T-bird Tim in forum Non Technical Forum
    Last Post: 04-29-2010, 01:25 PM
  3. Spark Plug insight... from a newbie
    By jleopold in forum Non Technical Forum
    Last Post: 07-18-2006, 05:32 PM
  4. Im the newbie!
    By Fordsho in forum New SC Owner Forum
    Last Post: 01-01-2006, 06:26 PM
  5. another newbie
    By driveway in forum Technical Forum
    Last Post: 03-01-2004, 09:51 PM
