Results 1 to 5 of 5
Thread: swap engine
    Oct 2013
    1
    swap engine
    hi all Im new on this forum .I have a t-bird sc 1993 my engine blow. i just whant no if i can swap with a 302 v8 carburetor in my car,thanks
    Oct 2013
    Lemont, IL
    7
    I'm sure this is possible. I would try posting in the proper sub forum and see who chimes in. Why not try and find another 3.8L to swap in? I'm sure this would be a much easier route to go. Welcome to SCCOA. I'm a new member myself.
    Milwaukee, Wisconsin
    3,294
    Smile you can put anything under the hood.
    Quote Originally Posted by jonathanwolf View Post
    These cars are bigger than people think. You could put a big block ford or chevy under the hood. I know I have done a few different engines into these cars. As long as you are going carb it is a cake walk to do....Rich
    Too many cars,too little time to drive them. Anything less than 500 cubes is a small block. If you slow down in life you will get run over..
    Sep 2002
    SE CT
    717
    Quote Originally Posted by pro street rich View Post
    BELIEVE IT! I am working on a BBF/T56 combo. Carb would be waaayyy easy! I'm shooting the EFI route myself on an early carb engine. Good luck and welcome!
    MikeH
    Feb 2013
    Custar, Ohio
    151
    you will need 91-93 Tbird 5.0L motor mounts, radiator too although a 4.6L radiator might work. you might also need to get the timing cover and waterpump from a 91-93 tbird 5.0L, due to clearances between pulley and radiator. Ford used a shorter waterpump design on these cars.
  1. FS 92 SC 5 speed with 95 engine swap. $1500
    By DeanWinchester in forum Cars for Sale
    Last Post: 03-27-2012, 02:07 AM
  2. When is a Coy Miller Race Engine not actually a Race Engine?
    By RalphSparveri in forum Non Technical Forum
    Last Post: 04-28-2006, 08:13 AM
  3. Cobra engine swap? Some ideas????
    By ricardoa1 in forum Technical Forum
    Last Post: 10-27-2005, 10:50 PM
  4. Engine Swap Questions
    By ThunderCoupe94 in forum Technical Forum
    Last Post: 10-15-2005, 05:42 PM
  5. HG's Fix original or swap engine?
    By Peterdroy66 in forum Super Coupe Club of Ontario
    Last Post: 03-07-2003, 06:59 PM
