Thread: shock install question
    Sep 2012
    nashville tn
    375
    I just replaced my shocks on the front and I am not to sure how far that nut is supposed to go down,is there a torque number for it? I don't have that so if someone could verify like an Inch or so it looks about right to me but I don't want to install it until I know for sure.
    Jul 2003
    Eastern (nee Western) PA
    4,993
    There probably is a torque spec. I am guessing 30-40 ft-lbs? But the main important thing is to make sure that the full weight of the car is on the springs when tightening. I would suggest tightening that nut and installing the ARC hardware last of all.
    God bless!!!
    Former Birds:
    Orem, UT
    5,902
    I tighten it with my impact, then put it on the car and run it down a little farther before putting the mounting plates for the ARC actuators. I don't hammer it down tight but I use the impact since its fast. Then I install the mounting plate and nut with a ratchet not super tight but tight by hand. That way it will come off again in the future with the right tools.
  1. Replies: 2
    Last Post: 09-14-2009, 02:03 AM
  2. BHJ install Question
    By darriantbird in forum Technical Forum
    Last Post: 11-03-2004, 07:17 PM
  3. Harmonic damper install tomorrow (question)
    By Jayls5 in forum Technical Forum
    Last Post: 10-22-2004, 12:47 PM
  4. please help with this shock question
    By puremuir in forum Super Coupe Club of Ontario
    Last Post: 08-18-2002, 10:01 PM
  5. Stock Shock Question........
    By pepito6SC in forum Technical Forum
    Last Post: 07-19-2002, 08:03 PM
