Results 1 to 2 of 2
Thread: 92 SC EEC test location?
    Sep 2013
    Glasford, IL
    97
    I have searched all over the engine bay and inside the car with no luck as to where the EEC test is at. My engine runs fine but then acts like a switch is flicked and won't rev over 3,000. It will come back to me and I'll have full power again just for it to go away. I have found two plugins on the right firewall. One is the ARC, and the other is missing the cap, but it doesn't have the Self-test wire. On my 95 it's where the 92's water reservoir is, but no luck finding the EEC test on the 92. Any suggestions would be very helpful.
    Jan 2008
    windsorlocks,ct
    170
    on my 93 the eec test is located on the passenger side firewall directly in front of the windshield cowl, it should be there, as for your problem it sounds like it could be a bad cam sensor? does the tach drop to zero do you get a engine light when this happens?
  2. EEC Location
    By jermenheinder in forum Technical Forum
    Last Post: 07-10-2005, 06:54 PM
  3. Emission Test - fail
    By SC Cid in forum Technical Forum
    Last Post: 06-04-2005, 12:56 PM
