Results 1 to 2 of 2
Thread: Bypass swap??
    Feb 2013
    Custar, Ohio
    152
    Bypass swap??
    Hello all, I started having issues with my T-stat housing leaking. I have noticed that the bleeder bolt is partly the cause of this problem ( tightening and loosening of the bolt, bending the pipe a lil also bending the flange.) I was wondering if it would be possible to swap over the bypass tube and T-stat housing from an LX or base model, to prevent this issue from happening again.
    Oct 2006
    48125,michigan
    4,173
    Quote Originally Posted by 90tbird4.7l View Post
    Sent you a pm
  1. How to: 4r70w swap
    By decipha in forum Technical Forum
    Last Post: 10-13-2013, 07:00 PM
  2. SC bypass question
    By bholmes in forum Technical Forum
    Last Post: 05-31-2012, 10:39 PM
  3. 1997 thunderbird 4.6 to 5.4 swap.
    By DSM in forum Technical Forum
    Last Post: 09-14-2010, 01:45 PM
  4. Engine Swap Questions
    By 85TbirdSC in forum Technical Forum
    Last Post: 12-03-2003, 07:39 AM
