Results 1 to 6 of 6
Thread: 5-Speed Conversion
    Feb 2005
    Republic of Texas
    2,577
    5-Speed Conversion
    I'm performing a 5-speed conversion to my Son's SC. My question, does the computer need to be changed during the swap? The years are as follows:
    Donor = 1989 (manual)
    Recipient = 1990 (automatic)
    I'm assuming that since the transmission isn't computer controlled (as in later years), the computer doesn't need to be swapped.
    Thanks,
    JD
    Apr 2005
    Canton, OH
    631
    5 spd conversion
    If you bypass the clutch positioning switch I think it should work. I did the swap on mine with a 93 but I swapped the EEC. You'd never know it started out as an automatic!
    Dallas, TX
    5,755
    AOD vs. 5 speed throttle response is different. AOD has a delayed throttle response, 5 speed is much quicker. Theory is that this has to do with extending the life of the torque converter. Bear in mind, the 5 speed was also normally equipped with EGR so an 89 5sp EEC is going to expect to find it and will toss a CEL if its not there.
    Feb 2005
    Republic of Texas
    2,577
    So what I think I'm hearing is to leave the AOD computer in the car to avoid the CEL. Throttle response will not be as sharp as with the 5-speed computer, but will work. Is this right?
    I only need to get this car through one more damn emissions inspection, then I don't care. I'll swap in the 5-speed computer to improve performance, and pull the CEL light. I won't even begin to mess with EGR.
    Thanks!
    JD
    Feb 2005
    Republic of Texas
    2,577
    Quote Originally Posted by txsc View Post
    Thanks!
    JD
    Also, I posted in the "Wanted" forum for one or two NOS or nice used clutch/brake pedal pads, but haven't gotten much response. Don't know if anyone is looking there very often.
    Can someone hook me up with one or two? My parts car has one that is marginal, and one that is junk.
    Thanks,
    JD
    Feb 2011
    642
    Quote Originally Posted by Cuztom Dreamz View Post
    Hey Evan since you will not return any calls or text
    Where are my parts or my money ????
    I should have known better huh ???
    Too bad you burned a good bridge !!!
    Angelo 954-548-1496 if you wanna make things right
  1. cooling fans not working
    By marcus in forum Technical Forum
    Last Post: 09-10-2014, 06:33 PM
  2. 5 speed conversion for sale
    By BlkSCnKS in forum Parts for Sale
    Last Post: 11-23-2012, 04:04 PM
  3. complete 5 speed conversion -shifter
    By ChadSC in forum Parts for Sale
    Last Post: 01-08-2011, 08:20 AM
  4. 5 speed conversion parts
    By Ddubb in forum Super Coupe Club of Northern California
    Last Post: 09-30-2008, 12:49 AM
  5. 6 speed tranny conversion
    By Randy N Connie in forum Technical Forum
    Last Post: 03-16-2003, 12:58 PM
