XR7 Dave
In order to have these in the hands of racers before the season starts we are starting another production run of these bushings now.
The bushing material is an extremely durable nylon polymer that is self lubricating and essentially indestructible (higher grade material then Delrin). This material has no give and will positively locate your rear control arm and knuckle assembly entirely eliminating wheel hop in all situations/conditions. Track times are significantly improved and control is dramatically improved. You will notice the difference.
Pins/sleeves are aircraft grade 2024 billet aluminum and then hard anodized for wear resistance.
All parts are CNC machined for consistency and tight tolerance. This is important to retain desired suspension articulation without binding. When properly installed these bushings make only a very minor impact on ride quality and NVH. If you have a high flow exhaust system you will not observe an undesirable change in noise or ride harshness.
The entire kit is $600, and that will include shipping in the lower 48 states. This is special pricing that applies to this production run only.
*Notes*
*Notes*
- Installation is an involved process. On a scale of 1-10 in difficulty this would be about a 7. Make sure you are capable of completing the install before ordering.
- This kit eliminates the "toe link" compensator.
- This kit is available for both cast steel SC control arms and Mark VIII aluminum arms. The kits are different, so you will have to specify. The bushings are not designed to work on the early stamped steel SC control arms.
- Some fitting may be required. It is impossible to predict the exact dimensions of all Ford components. This is one of the reasons Ford uses rubber. It will be your responsibility to ensure proper fitment of all components.
- Production is expected to take 6 weeks from the closing date of this order. This is an estimate only.
- Quality is guaranteed. All part will be inspected prior to shipping but if there is a problem prior to installation we will assist and/or correct the issue. Once the parts are installed there is no warranty or guarantee. Replacement components, should they ever be needed for any reason, can be ordered.
- These are COMPETITION BUSHINGS for OFFROAD AND RACING PURPOSES only. Proper maintenance and upkeep is essential for both performance reasons and your own safety. The responsibility for proper bolt torque and overall fitment is with the end user. SCUI accepts no responsibility for the use or installation of this competition only suspension kit.
