Results 1 to 15 of 16
Thread: Cutting coil springs
    May 2003
    Omaha, Nebraska
    6,207
    I have taken so much weight off the front end of the car that I now have a huge gap in the fender wheel to tire. I have the 1.5" lowering springs on the car now. My plan is to cut down a set of stock coils to bring the front end down to where it was when I had the chunk of iron setting over the engine called a supercharger. I need to lower it about 2". With an already 1.5" drop from lowering springs and 2 more inches, that would 3.5" lower than stock spring height. How many coils to cut off to acheive that. Is my math faulty? Anyone guess? Funny thing is I have to put a set of stock springs on in the rear to gain 1.5 inches. I will be doing the rear first to see if anything changes on the front.
    Ken
    93 SC Whipple powered 11.648 @ 119.6
    Twin Turbo, air intercooled..yet to see
    Feb 2003
    Tinton Falls, NJ
    1,536
    I'm going to guess about 1.5 or 2 coils to get down where you need to be. I would start with 1 coil though and then go from there. You can always cut more, but you can't add any back. Also a little trick, once you have cut 1 coil out of the spring, you can assemble and dis-assemble the spring and shock on the car without a spring compressor, just use a jack under the LCA and the weight of the car to compress the spring, and leave the top mount bolted in place and just loosen/tighten the center nut on the top of the shock.
    May 2003
    Omaha, Nebraska
    6,207
    One coil would equal about 1" or a little better? yeh a little at a time is probably best
    Ken
    PNW
    6,586
    May 2003
    Omaha, Nebraska
    6,207
    Nope didnt see the thread. Thanks, good information
    Ken
    20,947
    Ken,
    You need to do the rear springs first, because when you increase rear ride height it will lower the front. After you do the rear, then you can decide how much height you still need to remove from the front.
    May 2003
    Omaha, Nebraska
    6,207
    Ken,
    I am having the uber, super duper Supercoupe Unlimited bushings installed in the rear along with the stock height springs. Once done I will look and see if I have any drop on the front. Guess I better locate some stock fronts next. Time to check with my source down south for a set of them. I am sure you are right on the front dropping a little
    Ken
    Apr 2003
    Ventura, CA
    1,785
    Go slow. When I cut my rear springs, I cut 1/4 coil at at time, put it back together, drove around the block to settle it, lather, rinse, repeat until it was where I wanted. Yeah, it took forever, but it was easier than adding a coil back.
    20,947
    Quote Originally Posted by kenewagner View Post
    Ken
    On mine the front drops about equal to the increase in height on the rear, for the first inch or so then it's less. Easy to test if you have air bags.
    May 2003
    Omaha, Nebraska
    6,207
    I dont have air bags. If the stock springs dont bring the rear up I am pretty sure I will have to install them to get the height I want
    Ken
    May 2003
    Omaha, Nebraska
    6,207
    I should get the rear springs installed soon to see if I gain some much needed clearance. I bought a set of stock front springs to cut down. This is a picture of the front clearance I have with all the supercharger weight removed. The front has 1.5" lowered springs on it and one can see how much lower it needs to go
    Ken
    Greenville, IN
    4,328
    Hey ken - did you ever end up cutting your front springs? I'm getting ready to cut some non-sc springs a second time and just trying to get a good idea how much more if might need to take off the front. Got the back just right the first time, front still sits a little high though.
    I wonder if you measure the COMPRESSED spring when attempting to lower the car is the right way to do it. If you want to drop it two inches and cut off however many compressed coils = 2" of current ride height, it seems like that might give you a conservative estimate.
    Matt Haub
    Aug 2005
    Paoli Indiana
    4,619
    It will settle a little after a few days of driving so keep this in mind! also dont tightnen UCA bolts until wieght is on the car 1.5 coils in the front and one in the rear was perfect for me
    Greenville, IN
    4,328
    Quote Originally Posted by Jacob_Royer View Post
    I need DIMENSIONZ!
    I cut another half coil off the front but haven't driven it yet to let the suspension relax...I think it will end up about right +1/2" (or less) more than the back with the stereo in there.
    These springs are supposed to be Eibachs that were off a MarkVIII with the spring conversion. They have a stiffer spring rate than the typial lowering eibachs, but I didn't have an "initial ride height" to go off of. I got lucky and got the back right on the first try, the front were too high the first time and maybe about right the second time. Anyway, the stiffer springs feel great, hoping I don't have to take the struts off again though.
    Matt Haub
    May 2009
    Crystal, MN
    405
    Ken,
    I have my springs cut and I have done this to every SC I have owned.
    Personally, I think the car is at a great stance and handles better when I cut them. I have not experienced any of the traditional issues cut springs usually have with other cars.
    I chop 2 coils in front and 1 1/2 in rears.
  1. Cutting Coil Springs Question
    By nickleman60 in forum Non Technical Forum
    Last Post: 09-16-2013, 12:42 PM
  2. coil springs
    By gbabione in forum Technical Forum
    Last Post: 05-01-2003, 10:53 AM
  3. Coil Springs
    By Mack92SC in forum Technical Forum
    Last Post: 04-04-2003, 12:37 AM
  4. Adjustable Coil Spring Air Suspension Bag
    By danekejt in forum Non Technical Forum
    Last Post: 01-09-2003, 07:58 PM
  5. Does anyone have coil spring compressor???
    By YoshiRSC90 in forum Super Coupe Club of New Jersey
    Last Post: 05-01-2002, 11:16 PM
