My solid axle conversion is coming along nicely but I have a question.
The Strangle double adjustable shocks/spring have only about 1" of travel in compression at ride height. The shocks have integral bump stops which are rubber disks maybe 3/4" think mounted on the shaft of the shock under the spring.
Is this rubber disc enough or should I install external bump stops as well. The car is really not a street car at this point but may see some minimal use on the road.
You can see on the right side sock in the picture both the shock shaft and the bump stop under the spring.
