Page 1 of 6 12345 ... LastLast
Results 1 to 15 of 82
Thread: 93 SC (347 turbo) Engine damage and repair pics
    20,909
    Finally got motivated to pull the motor on my 93 SC today. Big thanks to Chris Wise for coming over to help. Expected to find a bent valve and some damage to the piston on the #4 cylinder where a valve spring dampner broke. It ended up being a lot worse.
    The head of the intake valve actually broke off and pretty much destroyed the combustion chamber, the piston and also damaged the cylinder wall slightly. Finally found the head of the #4 intake valve stuck inside the intake manifold in the #5 runner (opposite corner of motor). Turbine wheel also got damaged from smaller pieces of junk coming out of the cylinder. So instead of just fixing the heads and installing a new piston, it's going to need a full rebuild, with a new set of pistons and possibly a new set of heads.
    Here are some pictures of the carnage.
    20,909
    More pictures..............
    20,909
    Last one for today....
    St. Louis, MO
    6,390
    Wow, that valve stuck in the intake manifold is impressive.
    Kurt K (e-mail)
    SCCoA Member #: 443
    PNW
    6,400
    Ouch...well, at least you're over the hump and know the details now.
    ...and a turbo
    I had a valve break in a 289 one time and it did a 180, stabbed into the top of the piston and reverse fit into the valve seat in the head on the upstroke. Kind of turned a 4 cycle into a 2 1/2...
    Sep 2004
    Herrin Illinois
    3,392
    Wow that sucks David sorry to hear that news.
    member #2488
    Aug 2002
    3,660
    When did this happen? HOW does something like that happen? Wow.
    NYC
    17,430
    ouch..Suck something in??
    Jan 2005
    Northern Cambria PA
    1,623
    WOW! That sucks, what do you think caused it?
    May 2004
    Va. Beach,Va.
    6,951
    Damn, that sucks............Did that happen at the Shootout?
    SCCOA Member #2406
    '94 SC AUTO - $$$$ Pit
    Jul 2003
    Ottawa, Ohio
    5,400
    Yikes that some pretty impressive damage.
    SCCoA Member#: 2515
    1990 SC AOD 2.1L Kenne Bell
    11.676 @ 121.35 mph
    506hp/478tq
    Feb 2014
    840
    Sorry to hear....and see. That's gotta be a tough one to take. I almost feel more pain for vehicles than people.
    Feb 2003
    Tinton Falls, NJ
    1,508
    Ouch! That is a major setback. Is that a dart block? If so, I think it can be bored out to 4.125", which would give you 363ci.
    20,909
    Quote Originally Posted by Toms-SC View Post
    Tom,
    It happened in early November just before the local track closed for the winter. Since the car had some issues at the Shootout and only made one clean pass I wanted to take another crack at getting a 9 second time slip while the car was still full of race fuel and had the slicks and skinnys mounted.
    This pass went pretty good except for spinning the tires hard coming off the starting line and resulted in a 10.067 @ 139.65
    Decided to give it another try with tire pressure reduced a little and boost slightly higher. Everything was okay until about the 1/8 mile point when is suddenly lost a lot of power and felt like it was missing. Thought it was just a burnt a plug wire or something simple, but as you can see it turned out to be a lot worse. This is the video when it broke.
    http://youtu.be/HRZgiW2lTHg
    From what I can tell it all this damage was caused by a valve spring dampner breaking on the #4 cylinder intake valve. The springs were iffy at the rpms I was turning and probably should have been upgraded to beehive style a couple years ago.
    20,909
    Yes, it's an iron eagle Dart block and can be bored another .125" for 363 cubic inches, but I'll probably just go another .020" or whatever it takes to clean up the damaged bore to keep the displacement as close to 347 as possible. The PT76-GTS turbo I'm currently using would need to be replaced by something with a bigger turbine to avoid increasing the exhaust back pressure if I went all the way to 363. Not really interested in doing that right now. The turbo can be repaired pretty easily and is the least of my concerns.
    I need to take a little time and explore my options on machine work for the block and determine if the AFR 205 heads are even worth repairing.
  1. 93 SC supercharger and engine parts
    By sgent in forum Parts for Sale
    Last Post: 06-08-2011, 03:27 PM
  2. Replies: 11
    Last Post: 05-03-2010, 02:26 AM
  3. 89-93 SC Radiator A/T $50 *PIC*
    By GumbyGrn in forum Parts for Sale
    Last Post: 08-05-2008, 07:51 PM
  4. '93 SC - Midnight Blue in NY - PICS
    By MSG419 in forum Cars for Sale
    Last Post: 10-25-2006, 11:56 PM
  5. 347 turbo motor progress pics
    By David Neibert in forum Non Technical Forum
    Last Post: 07-28-2004, 09:15 PM
