Page 1 of 5 12345 LastLast
Results 1 to 15 of 74
Thread: Angry Bird update and electrical ID
    Oct 2012
    Lynden, WA USA
    222
    Hi all,
    It was this time last year that I was peppering this forum with questions like a 5 year old! What's this? What's that? Well, I ended up having a super driving season with a well behaved 89 SC in the body of an old pick-up.
    This past winter, I tore it down again, boxed the frame (the IRS and IFS needed a stronger frame!), painted the chassis parts and rebuilt the front end. I also moved the gas tank to a saddle position, but maintained the T-bird fuel outlet.
    I managed to trim some more of the original wiring harness, and continue to do so, but this year with more caution. The last pic I attach is of a connection that has a plug in it and located up front in the same splice as the horns and front LH ground buss. Since it is plugged, perhaps it was for an option that was not on the donor car. If so, what was it for?
    Hope all are doing well. I loiter on this forum occasionally, but havent had much reason to post. I will update more when I finish the work for this driving season.
    Thanks,
    John LName:  a. 56 F100 SC side front view.jpg
Size:  427.0 KBName:  56 f100 frame rebuild 3-14.jpg
Size:  417.5 KBName:  10 Clean & Painted T-bird 8.8 IRS.jpg
Size:  417.6 KBName:  Another mystery connection - front LH engine bay.jpg
    Jul 2013
    LI, NY
    788
    Awesome project!!! Looks great. Thanks for the photos. I love when people get creative like that...
    Madison, Ohio
    17,574
    Awesome grumpy truck!
    That plug is for daytime running lights that your car didn't have.
    Email me here.
    PNW
    6,546
    Cars sold in Canada had DRL. I've been looking, but I haven't seen one so equipped here in the states yet.
    Your progress looks great - still going to make the show?
    Ken
    Oct 2012
    Lynden, WA USA
    222
    Thanks gang for the help and compliments!
    I could not find connection listed in my EVTM - were you able to locate it there, or is this once again just the impressive knowledge base that exists on this forum?
    Are there any useful circuits in this plug? Any switched circuits, etc that may prove useful for accessories I may add in the future? I am preparing to lobe it off otherwise.
    What show are you referring to Ken? My target is to be at a Memorial Day show in Bellingham. This weekend, I will get the front clip back on including electric to everywhere. If the electric checks out, I should be out of the woods!
    John L.
    PNW
    6,546
    I run DRL LEDs, but they are switched/wired direct from a key-on hot. If I could find the matching factory female connector I'd look into using that circuit instead.
    I haven't pulled the cap on that connector - is it just a plug or does it bridge those circuits? You may just be able to de-pin the connector and then wrap/hide the leads against the harness, but they will be hot at times, so be careful. If you can clip those out and seal/isolate and be more clean than the factory stub, I'd go for it. Maybe split the harness and delete the tails there. I think you know the routine
    Weren't you going to some show in Long Beach...?
    Madison, Ohio
    17,574
    If you want DTRL all you need to do is get a Canadian to send you the module and plug it in. As for the plug and associated wiring, it all has to do with the factory cluster/multifunction switch and headlight controls. You can remove that whole thing if you aren't using the SC headlight wiring.
    Email me here.
    Oct 2012
    Lynden, WA USA
    222
    Good points Ken. I will pull the plug to make sure it isn't bridging anything. But my point is indeed to back it out of there, at least to the junction point. I am doing the same with some secondary ABS leads that are not being used.
    I used the original harness because I incorporated the entire interior from the bird. Includes gauge pod, steering column with all switches, lights (except DRL!!), gas pump/sending unit, seats, etc. It would be just as lengthy to list what I've deleted, but it was a bunch.
    Yes Ken, you are correct. I was trying to get it dependable enough to take it down there in Sept. I took it to a local show last year and was the only rat rod entry. But wow, good crowd reaction as they ignored nicely painted cars all around the truck, with lots of curiosity about the T-bird drivetrain.
    Madison, Ohio
    17,574
    There is a jumper in there. I forget what the jumpered circuit is for, but autolamps comes to mind.
    Do you mind if I share some of these pics on FB? I think the truck is one of the coolest things I know.
    Email me here.
    20,939
    Very cool project !
    Oct 2012
    Lynden, WA USA
    222
    Thanks for the clue on that circuit, Dave. I do use the auto lamp function, so I will still do some pruning, but keep the jumpered lines connected.
    Feel free to use any pics you see. Your're welcome to any pics. I keep a photobucket album public for it. Appreciate the positive feedback!! Attached is a matching pic to the first one in this post.
    Just a couple of months ago, I tracked down a more appropriate forum for this style of rod, and a build thread can be found there:
    http://ratrodsrule.com/forum/showthread.php?t=31026
    The build thread is retroactive, as it took an a few fits and starts with other less classy sites to choose ratrodsrule.com as "home". I talked the SC forum up on my postings as a very helpful group, so maybe you will see more V6s living on in a new lifestyle.
    Jun 2008
    Columbia,SC
    623
    Not to thread jack, and nice truck by the way, I have dtrl and French throughout my car that I just picked up from thunder Dave, so is it safe to assume I have a Canadian bird? I thought I read that they didn't have the sliding seat belts but I do.
    Apr 2003
    Ventura, CA
    1,781
    Nice F100. Since viewing pics on that other forum requires us to register, can you post a pic or two of your front suspension/brakes? What calipers are those, SSBC?
    Oct 2012
    Lynden, WA USA
    222
    Sorry about wasting everyones time on that link! Try my photobucket link to see pics of the IFS installation. It is the only thing on the truck that is not T-bird - it is from a Jaguar XJ-6, including 11" disks and 4 piston calipers.
    http://s647.photobucket.com/user/jcl...-100%20Pick-up
    The photobucket album was not updated recently, so not as complete as the first link, but you shouldnt have to register.
    A further thought on the DRL function - I thought that was a standard feature, as mine worked in that fashion last year. Then I recalled that the light sensor for the auto function was buried under my dashboard and because it was always dark under there, I had DRL by default. So there you go. A piece of black electrical tape over the light sensor will get you the DRL option on the cheap!
    John L.
    Oct 2012
    Lynden, WA USA
    222
    Another electrical ID issue
    I am down to the final connection details and can find a connecting point for this pigtail. It comes out of the speed control servo and for some reason has a connection into the pigtail adapter shown. Coming out of the servo the wires are Orange, Grey and White, while the pigtail wires are Yellow, grey and white.
    What do they connect to?Name:  Speed control wire.jpg
Size:  361.6 KBName:  Speed control wire.jpg
  1. difference between SVT T-bird rim and "R" rim?
    By bigcletus94 in forum Non Technical Forum
    Last Post: 11-14-2002, 10:40 PM
  2. New T Bird update
    By PETEp in forum Super Coupe Club of New England
    Last Post: 09-07-2002, 04:52 PM
  3. T-Bird SVTs, and your opinions...
    By MN12 KID in forum Polls Forum
    Last Post: 09-01-2001, 08:25 PM
  4. 2002 T-Bird Introduction and Super Ford Weekend...
    By Derek R in forum Super Coupe Club of the Midwest
    Last Post: 07-19-2001, 08:46 PM
  5. Website Update and VP's Named
    By Lugen in forum Super Coupe Club of Greater New York
    Last Post: 03-28-2001, 01:05 AM
