Woohoo car starts and kinda runs again, Thanks for all the help!..... But now it starts and runs but won't hold an idle, you need to keep revs above 1000rpm or if you release the throttle it just turns off, but no problem restarting it. It didn't do this before the damper broke, just started when I got the car running today. I did remove all the pipes for the supercharger side only to replace the nuts to the intercooler and hat. Could I have not seated the pipes correctly and causing a vacuum leak, even though I don't hear any leaks, I have no check engine lights and plan to scan it tomorrow. When I turn the key on (engine off),the shift light doesn't turn off but it doesn't blink either, anyone with some suggestions
